Our city recently phased out its coal burning electrical plant, and installed a natural gas generating station.
The government, in their infinite wisdumb, said that the new plant must be as efficient as possible, so they drilled a well into the aquafier for cooling water.
They drew contaminates from the adjacent ground under the coal-fired station, and began contaminating the drinking water for a city of 600,000.
The midsouth US where I live is frequented by tornadoes and bad weather during the summer, and this city is full of large trees, so power outages happen a lot, and can last for up to two weeks depending on the severity of the storm.
Ice storms are the worst because the trees shed limbs, and knock down random power lines all over the city.
My house does have natural gas heat, and so far, the gas service has never been interrupted.
I can run my fan/coil unit on a small generator, and use the natural gas to heat the house.
My next door neighbor has an all electric house, and when her power goes out in the winter, she has no good way to heat her house.
After the last ice storm here, which I think was about a year ago, we were out of power for about a week, and so I purchased a 7.5KW gasoline genset. I work at home, and so it is critical that I be able to keep working regardless.
I use a 120/240 volt, 3-wire connection, and I use a large cord and twistlock plug to connect my house electrical panel to the genset.
I have a main breaker on my electrical panel, and so I manually open the main, plug in the genset, and then close the genset breaker. This allows me to operate my entire house on the genset, as long as I don't exceed 5.0 kw continuous.
The biggest thing to avoid is having a refrigerator/freezer full of food go bad.
For me, I have to keep working and remain on the internet at all times, and so that is also critical.
I have camped out in the winter in 18F weather, and that is no big deal, but there is nothing like having a nice warm house when the power is out during the winter.
The Honda genset I bought is super quite, and uses an inverter for clean power.
I can hardly hear the genset running from inside the house.
I despise loud generators, especially when trying to sleep at night.
Edited By PatJ on 28/07/2022 13:46:27
