Cheap stuff
Cheap stuff
Home Forums The Tea Room Cheap stuff
Viewing 25 posts - 1 through 25 (of 61 total)
  • #36840
    Steviegtr
      @steviegtr
      Buying cheap things
      Steviegtr
        @steviegtr
        So it does not cost a lot to populate your workshop
        Steve.
        Edited By Steviegtr on 26/04/2022 04:27:27
        #595829
          Buy cheap, buy twice? Not going to watch that one.
          #595837
            dont know
            Perhaps ‘Cheap’ is a candidate for my list of ambiguous words.
            Nick Wheeler
              @nickwheeler
              Posted by not done it yet on 26/04/2022 08:11:23:
              How about buy cheap, get the job done, move on? Would you watch that?
              #595840
                Hear hear. My workshop is almost entirely populated by good quality gear that I bought cheap cheap secondhand at garage sales, including my Myford lathe. I started off with just my old apprentice days toolbox and now have a fully equipped workshop full of welders, torches, 20 ton press, lathe, grinders, vices, two drill presses, and boxes and boxes of hand tools, drills, reamers, micrometers etc etc. Even the workbenches are reworked kitchen benchtops. Storage shelves and cupboards also sourced for next to nowt.
                For an investment of a bit of pocket change here and a bit there. It just took two years of getting up at 6am on Saturday mornings to be first in at the best looking garage sales and get the good deals. I am now better set up than some of the "professional" workshops I was paid to work in years ago. And I get to work with very nice British/Aussie/US made equipment. Always a pleasure.
                I have only recently started buying brand new insert tooling and other specialised bits and pieces as I have reached the end of what is available secondhand locally in the non-industrial rural area that I live in.
                Edited By Hopper on 26/04/2022 09:17:10
                #595842
                Pero
                  @pero
                  Interesting topic. I have an excessively large number of tools ranging from the very cheap ( early days of no money ) to the very expensive ( still no money – spent it all on tools ).
                  These days I look at a tool in terms of whether or not it will do the job rather than initially looking at the cost. At my age it doesn't have to last for a hundred years – 10 would be good, 20 outstanding and 30 a miracle ( that's me rather than the tools ).
                  For example, I have never worn out a power tool no matter how cheap or expensive. I just don't use them that much and do not overwork them when I do. A tradesman's approach could well differ, although locally at least some are using cheaper electric tools, basically as a disposable item. Admittedly the more expensive tools may feel more comfortable in use but the job they do is just the same although occasionally a little slower..
                  I have in my time killed a few cheap hand tools through gross miss-use – pliers and screwdrivers come to mind but I am still using some Chinese jeweller's files bought for little money decades ago and used mostly on 316 stainless steel. Not everything cheap is bad.
                  Currently industrial machine tooling ex China can be had at very good value for money. Improved manufacturing and the need to provide high precision for use in today's CNC tools means that accurate tooling for the owner of larger manual machines is readily available at low cost. This does not however necessarily translate to tooling for hobby size machines where older manufacturing processes may still be employed.
                  The questions to ask – will it do the job to the standard I require and will it last the distance. If the cheaper tool will do the job go for it. There will be good use for the money left over.
                  My two bobs worth.
                  Pero
                  #595843
                  Circlip
                    @circlip
                    Don't understand why so many can't recognise Yorkshire frugality? Keep up the good work Steve.wink
                    Regards Ian.
                    #595844
                    Dalboy
                      @dalboy
                      I always look at it as, if I use it the very odd time then cheaper products will do on the other side if it gets a lot of use then more is spent on it(Better quality).
                      I am not worried if I buy second hand as some of those can be of good quality yet cheap
                      #595845
                      Neil Lickfold
                        @neillickfold44316
                        A cheap lathe repaired or a cheap mill repaired is better than No lathe and No mill.
                        Some don't have any of the good iron machines around. One thing that I have learnt is that if the oil or lube is black or very dark in colour, that's because material particles are in that oil and it's wearing out.
                        I am testing the idea of using the linear rail grease from DMG as a slideway lube on my new to me cheap mill that is not really cheap after the upgrade rework etc. But is still cheaper and is in my shop as opposed to Not having a machine of that capacity.
                        Being lucky to get measuring tools at the right price is a good way to make the hobby budget go a long way. I was fortunate to be given a Tesa 0-30 mm micrometer that did not go. Turned out that a cable was damaged. So I cut it shorter by 1mm and pushed the cable into it's connector properly.
                        Cheap cutters and cheap drills that are not really up to do the job end up costing a lot more. Garage sales often have a few little gems if you are early on the scene.
                        Really good tool holders, especially Boring bars can really make the difference , especially in the insert life and sometimes in surface finish. My roughing inserts are finishing inserts that have some wear, but are not worn out.
                        Ady1
                          @ady1
                          I sometimes get cheap stuff which gives you a lot for your money, and then focus on improving its limitations or use it to create a more useful project
                          My Lidl bench drill is still sittlng gathering dust for 69 quid but for that money I got a whole bunch of bits
                          Nearly used one of the triple belt pulleys last year but found an alternative
                          Pulleys are 20 quid a pop on ebay and that Lidl drill has two triples and a quadruple pulley before you even look at the rest of it
                          #595847
                            Not everyone is as well served by local second-hand goodies as Hopper and Steve! Steve couldn't have made his video in my part of the world because my part of England is an engineering desert. Most local light engineering closed down nearly 50 years ago and the high-end survivors don't use centre drills or HSS! In consequence boot sales and auctions rarely have tools worth buying. Only battered rusty tools at inflated prices.
                            Steve's bargains come from nearby businesses that have either hit the rocks or are modernising or outsourcing. He's enjoying an opportunity which isn't reliable or sustainable in the long run.
                            As a schoolboy my first hobby was amateur radio and we all lusted after equipment costing new as much as a posh car or a house. Used to joke that "World War 2 was my playground" because huge amounts of surplus radio and other ex-military gear was dumped after the war. London's Lyle Street specialised in shops selling it and the two decades after 1950 were a golden age of electronic experimentation. By the seventies the apparently inexhaustable well of government surplus was running dry: air and sea fleets scrapped, regiments disbanded and all the depots were emptied. And equipment made in 1945 was well past its best-before date by 1980. The Cold War helped a bit, but surplus was never the same again. Today, radios that could be had for shillings and cannabalised, cost thousands and are highly collectable.
                            I think old tools will disappear in the same way as WW2 radios. Enjoy it while it lasts!
                              The other problem with cheap from boot fairs etc is that you are stuffed if you want the item at a particular time. OK if you can put the job on hold for 6 or 12months until you find the item you want cheap. Those that want to get on have to buy what's available at the time and decide on the quality they are happy to pay for.
                              As I see it those two sets of knurls are not that cheap as Steve now has 3 sets of wheels and only the expensive ones fit so that's £2 sitting in a draw not being usedsmile p
                              #595853
                                Posted by SillyOldDuffer on 26/04/2022 10:11:17:
                                Not everyone is as well served by local second-hand goodies as Hopper and Steve! Steve couldn't have made his video in my part of the world because my part of England is an engineering desert. Most local light engineering closed down nearly 50 years ago and the high-end survivors don't use centre drills or HSS! In consequence boot sales and auctions rarely have tools worth buying. Only battered rusty tools at inflated prices….
                                Dave you may have no idea what an engineering desert is. I can't even buy a piece of bright mild steel where I live, 1,000 miles north of the state capital of Brisbane, which is the state's main industrial centre. Other than a few mining industry workshops  that are only about 500 miles south of me, all there is around here is sugar cane farms and Barrier Reef and rainforest tourism. There are a few small workshops servicing cane harvesters and trucks, or reef boats, and one sugar mill.
                                I can't tell you how many dozens and dozens of garage sales I used to go to go to that if they had tools at all, were the usual array of carpenters and home renovators' tools, before I would hit "pay dirt" and find some engineering related tools. Very, very rare. And finding a Myford lathe was a once in a lifetime deal. It was only there because it was the most clapped out lathe I have ever seen, after 60 years or so of abuse in the local electric motor rebuilding shop.
                                So it can be done. As i said, all it took was getting up at 6am every Saturday morning and hitting as many garage sales as possible in the hope of striking pay dirt, for two years or more. But it was time well spent and was always a great social occasion getting around chatting to all sorts of people in the process. . My workshop would have cost tens of thousands of dollars to set up with all new equipment.
                                But then a few years ago, the already small supply of engineering tools seemed to dry up. Garage sales seemed to get smaller and fewer as more people used eBay, Gumtree and Facebook Marketplace to sell individual things for more money. I went for 12 months without hitting a single good garage sale with tools I needed, so gave it up in the end. So maybe you are right that the glory days of cheap used tool buying are drawing to a close. Or maybe it was in part because I already had most common tools so I was getting fussier in what I bought.
                                Jason, I used to buy up all sorts of tools that I did not need but looked like they could be handy one day, so when I needed them, they were there. Trouble is they sit unused so long I forget that I have them, or forget where I put them!
                                Edited By Hopper on 26/04/2022 11:04:46
                                Edited By Hopper on 26/04/2022 11:16:34
                                #595856
                                Bountyboy
                                  @bountyboy
                                  Couldn't agree more with Hopper & Steve, there are bargains to be had at car boots sales. Luckily I live near B'ham so there are plenty of car boots to visit with engineering tools for sale.
                                  Steve showed an Albrecht keyless chuck he bought for peanuts, excellent buy, wish I was so lucky.
                                  #595860
                                  Nick Wheeler
                                    @nickwheeler
                                    Posted by Bountyboy on 26/04/2022 11:30:45:
                                    There are. Sometimes. But how often do you go to a bootfair with the intention of buying a good quality 50mm boring head and actually manage to do so? Usually you walk past a load of stuff that looks like it was just pulled out of a skip, pay £5 for a slime burger and go home with a couple of £0.50 Matchbox cars that remind you of the ones you ruined as a kid. On the rare occasions I see engineering stuff it's either the contents of another skip, or priced for the collectors who only buy pre-war Starret in original boxes.
                                    Scouring the secondhand market for two years is a huge cost in time, and a fair amount of money. When I bought my first mini-lathe, I looked at several Myfords locally that were 2 to 3 times the price. They were worthless to me, as I had work to do that wasn't restoring a used-up piece of machinery.
                                    #595865
                                      Posted by Nicholas Wheeler 1 on 26/04/2022 11:50:35:
                                      That's the thing. I had more time than money so scouring garage sales was a pleasure. And restoring clapped out old machine tools turned out to be a pleasant hobby that has taken over my workshop! Once the restoration was completed, there is no end of accessories to make for it. Horses for courses.
                                      #595895
                                      Samsaranda
                                        @samsaranda
                                        A few years ago I was picking up new, unused end mills and slot drills, some were top quality carbide, from eBay, they were advertised as items from individual sellers who were not selling professionally. My Best Buy was a top quality 16 mm carbide end mill, totally unused, I think I paid no more than a fiver for it. I wondered how so many new milling cutters were available on line and came to the conclusion that people working in engineering must have been putting them in their pockets and taking them home and then advertising on eBay. I managed to build up quite a store of end mills and slot drills but nowadays the supply has dried up and very few are advertised and usually the price is the same as retail. Dave W
                                        #595900
                                          Posted by Nicholas Wheeler 1 on 26/04/2022 09:12:58:
                                          Probably not. I’m a bit choosy when it comes to videos. I do recall his ‘cheap’ knurling tool. That was enough on the topic.
                                          As for gillie and his list of ambiguous words – I have avoided reading that thread, too.
                                          #595907
                                          Mick B1
                                            @mickb1
                                            I think it's clear that what you can realistically get cheap depends on your needs/wants, the industrial activity and history of the place you live, and the balance between the savings you can expect and the time you're able and willing to spend bargain-hunting.
                                            For myself, the best cheap thing I have is a big Record 110 vice with quick release that came to me for £2 when they closed the toolroom at ITT Creed in 1981, where I was working as a tool designer.
                                            Then I have a 0.0005" x 0.300" Baty dial gauge set up for me in the later 80s by their chief inspector. It works very smoothly.
                                            I bought a cheap B&Q bench drill in about 1995 which I still have. I think it cost about 25 quid. I set it to its middle speed and don't think I've ever changed it for whatever size drill I was using. It rumbles and clatters and I regularly threaten it with replacement when that irritates me, but it actually still delivers decent work for anything I've put to it.
                                            I buy cheap bench grinders and don't mind replacing them every 15 years or so. 'Buy cheap, buy twice' ain't necessarily a bad way to be going on.
                                            smiley
                                            #595918
                                            Jon Lawes
                                              @jonlawes51698
                                              My Pillar Drill was lend/lease from the USA. Can't get cheaper than that, unless of course they ask for back-rent.
                                              #595931
                                              Stephen Follows
                                                @stephenfollows82099
                                                I’ve gone through three Dremel mini drills in two years, not used a lot either. Top money for junk.
                                                #595937
                                                bernard towers
                                                  @bernardtowers37738
                                                  that means at least two of them are still in warranty!!!
                                                  #595944
                                                  Bill Phinn
                                                    @billphinn90025
                                                    I'd love to have the time and freedom to be a regular, or even a once-in-a-while, car-boot sale truffle hound; sadly, I don't. Having things delivered is really the only option for me.
                                                    I know I miss out on potentially fabulous serendipitous discoveries as a consequence, but at least the stuff I need is usually available somewhere on the Internet. Even then, though, buying what I need comes with no guarantee that I will have the time to make use of it anywhere near to the date of purchase.
                                                    #596115
                                                    Steviegtr
                                                      @steviegtr
                                                      Posted by not done it yet on 26/04/2022 15:30:53:
                                                      What a shame there are such members that just do not want to be educated. I tried not to respond to this stupid comment. but could not resist. My dad was a plonker. I looked up to him at the time , but realised after a time that he was talking rubbish most of the time.
                                                      All the cheap items i bought were not cheap rubbish but good quality items for not much money. I will be doing another video soon of what can be bought for pennies. A good example was a Mitututo spelt wrong . Height gauge 18" the digital version . Listed at around £450. I bought for £35 from a well known auction That also came with a 18" version that was vernier. So am i so not stupid as NDIY seems to think
                                                      The items that i showed were good stuff. I.E the centre drills were unused Dormer's. The knurles were of what seemed good quality, but i already had sent to me by youtuber's more than a dozen others. Which were all top quality items.
                                                      I am so sorry for posting this link to people who will disrespect my video's. It is to them i apologise. To the rest of you guy's who like this sort of content , then i will continue. By now i guess you have noticed that i am quite thick skinned & ignore mostly old men that are angry at the world for some strange reason. NDIY .You could have said. Great video Steve, or even Steve that video was not very good. To make it better you should have, ????. Most with no TV license & are skint.
                                                      Tip of the week is , you should have saved more when you were working . That way you could could visit car booties instead of planting potatoes & try to belittle others of greater intelect than you have. What are you doing in 2022.
                                                      In the morning going to have a new 190 Road 5 tyre fitted to the Ducati Multi s. Then taxing the ftype, so i can go out & do some drone footage . Then hopefully continuing with retracting wheels on the new to me bandsaw.
                                                      I am also pretty ashamed at Jason. You are a moderator on this site & also disrepectected me. By buying 4 cheap knulring wheels for a paultry £ 2. Why would you not think that in the future i would not make a bigger version & use those knurles for not much money would come in useful . I watch all your youtube video's & respect them all. Even though you never speak or show your mug.
                                                      I know i am fortunate to be able to do things others , can not do due to financial constraints, but that should not alienate me.
                                                      Regards to all.
                                                      I will be 70 yrs old in a few days & have always respected other people. I have always tried to to stay fit & well, even having Cancer twice i fight on. I hope all you members that read this post will do the same. Life is quite short , so make the most of it. Most of all do not disrespect other members like you know who does.
                                                      Thank you for reading this post.
                                                      Steve.
