(1)
The rattling fit beloved of clockmakers is actually good engineering practice not the opposite . Given the set of running conditions existing at pivots in clocks a loose fit is what a design engineer would choose .
Motion in most clocks is intermittent tick – pause – tick – pause ad infinitum . As each tick is initiated the small amount of force available has to ' unstick ' the pivot journal in its bearing before any actual movement can occur . Simple turning to unstick requires relatively a large force but clockmakers must have realised very early on that if the bearing is a little oversize then the pivot journal can begin its motion with a minute ' epicyclic ' type roll – which requires relatively a small force – before beginning main part of motion .
This situation is very similar to the one which exists where O rings are put in elongated grooves in pistons so as to reduce starting force and stiction effects ..
A secondary reason for making clock bearings slightly oversize is to improve dirt tolerance .
For the clock in general making engagement fits consistently loose everywhere improves the tolerance of the clock to random wear in the working parts over many years .
(2)
Ball bearings only have lower friction values relative to plain journal bearings of similar size when both are new and clean . Given any accumulation of atmospheric dust and goo the ball bearing rapidly stiffens up whereas the plain journal bearing is much more tolerant .
(3) Just on the basis of gearing theory it would seem at first glance that a clock wheel to engage a lantern pinion should have different tooth profile to a clockwheel engaging a conventional toothed pinion .
(4) Just out of interest – there are many applications in the aerospace industry where components in an assembly are a rattling fit when the assembly is in cold / static condition . Looseness may be designed in to allow guaranteed freedom of motion under very harsh working conditions or alternatively designed to take up under working conditions to give normal running clearances .
MikeW
Edited By MICHAEL WILLIAMS on 31/07/2013 19:21:50
