There were many electric cars and small lorries built in the 1900s, in Britain, France and the USA – but of course soon rendered largely obsolete by the development of the petrol engine of increasing reliability, smaller bulk and weight, longer range and simple, rapid refuelling.
My copy of Modern Electrical Engineering, Vol 5, devotes an entire chapter to them, detailing the various and ingenious motor designs, gives the following nugget in explaining their " somewhat meteoric rise ", especially "among the wealthier classes " :
The unreliability and noise of early i.c. engines was the main factor, but in London a regulation
" … prohibited the use of the petrol-driven vehicles in the royal parks, but permitted entry of the silent and odourless electric cars. " [1]
One of the books' exemplars, illustrated by a re-touched photo probably from the manufacturer's own advertising, was the Lloyd 3-ton lorry, built by the Bremen-based North German Lloyd Steamship Company. This, or the model photographed at least, was in outline rather like the open-cab, bluff-fronted steam-wagons by Thorneycroft, Hindley (1908) etc.. Of its artillery-pattern, (solid-?) rubber-tyred wheels, the Ackermann-steered front were the powered ones, each with its own motor suspended from the hub.
The writer describes the Great Eastern Railway tested a Lloyd for a week on goods deliveries around Ipswich, which has hills up to about 1 in 12. They quoted a mean 7.4 A/h per mile: I wonder how that would compare with a modern version in a fair test, given that it would still take the same energy to move the same gross mass from rest to the same speed – and to get it up Mt. Ipswich; i.e. a comparison of overall efficiency.
The book does compare the Lloyd with similar-capacity lorries using rear-wheel chain drive, ascribing the Lloyd's better efficiency, by about 8:7, to it using regenerative braking.
We also learn a very similar vehicle to the Lloyd, named 'The Orwell' " is now being built by Messrs. Ransomes, Sims & Jeffries Ltd., of Ipswich. "
Some makers went further, putting the motor within the wheel, notably the 'Cedes'. These British products in 6,15 and 25HP sizes, of claimed efficiencies c.80%, were intended for electric buses and similar heavy vehicles.
Over in France, Paris City Council's municipal sanitary services operated 100 of the Fram equivalent to the Cedes. The Fram is rather tantalisingly described as a sort of forecarriage that can be attached to any form of vehicle. It's not clear, but I read that as not articulated but a front-end unit bolted rigidly to a finish-builder's chassis.
In the States, the impressively-named 'Couple-gear Freight-wheel Company', of Grand Rapids, Michigan, developed an ingenious and compact wheel whose motor lay across the space between two felloes. Each felloe carried a bevel gear meshed with a pinion on its respective end of the armature shaft. The motor was placed slightly askew to allow this arrangement.
The CgFw Co. also built a lorry with powered wheels all round, its motors supplied from a dynamo driven by a petrol engine…
So city-centre vehicular noise and fumes, battery-electrics, hybrids, regenerative braking…. Nowt new under the Sun, it appears.
[1] Modern Electrical Engineering, Vol.5., ed. Magnus Maclean, M.A. D.Sc.,., pub. The Gresham Publishing Company ltd., London. Date not given but the above and other evidence suggests the 19-teens.
