15-day Skeleton Timepiece
Home Forums Clocks and Scientific Instruments 15-day Skeleton Timepiece
Viewing 25 posts - 1 through 25 (of 41 total)
  • #82777
    Russell Eberhardt
      @russelleberhardt48058
      After several years of model engineering and as my grandfather, great grandfather, and great great grandfather were all watch and clock makers I have decided to make my own clock.
      I have chosen John Parslow’s skeleton clock as it is described as being suitable for beginners to clockmaking and looks nice.
      Having started it I have found that he assumes rather a lot of clockmaking knowledge so have been reading up on techniques and nomenclature. I have also found quite a few errors in the articles (some, but not all, of which were corrected in later articles) so I will note them here in case it helps anyone else:
      1. The material list omits the brass for the minute wheel. This should be 1.5 in Dia. x 3/32.
      2. The 4 mm winding key specified will not fit on the 0.18 AF end of the barrel arbor. The correct key is 4.5 mm.
      3. The suspension spring should be part no. S5516.
      4. The mainspring should be part no. 0321 204515.
      5. He gives some rather odd dimensions for the bores of the wheel collets and pinions. I’m using the following drill sizes:
      0.78 2 mm.
      0.85 #44
      0.112 #33
      0.118 3 mm.
      That’s all for now – back to the workshop.
      Russell.
      Russell Eberhardt
        #82783
        johnp10
          @johnp10
          Hello Mr Eberhardt,
          If you will kindly contact me at johnp10@ virginmedia.com I will endeavour to answer your queries.
          Regards.
          John Parslow.
          #82857
          johnp10
            @johnp10
            I must thank Mr Eberhardt for pointing out that a number of errors the have crept into the 15 day skeleton clock series in M.E. from 28 March to 15 August 2008.
            Items 1,2,3 & 4 in Mr. Eberhardt`s list are correct as printed.
            The drills that I used were standard Imperial sizes when the clock was first built but there is no reason that the sizes suggested by Mr. Eberhardt should not be used as long the diameters of their matching arbors are adjusted to fit.
            John Parslow.
            #82872
            Mogens Kilde
              @mogenskilde92996
              Hello Folks
              As Mr. Eberhardt has started this topic, I simply have to show my progress on making the very same clock.
              Previous you all have been kind to give me some feedback on the tool making for the project.
              In the building proces I have made metric design of all parts, as you might see the next step is the ThirdWheel section.
              So far the project has been very interresting, so I would like to thank Mr. Parslow for his design of this clock.
              Mogens
              #82980
              Russell Eberhardt
                Morgens,
                It’s looking good so far.
                John,
                The drill sizes I came up with are the closest I could find to the decimal dimensions in the article. The metric ones are closer than the nearest number drills. Of course, as you say, it doesn’t really matter as the parts should be made to fit.
                A question when it comes to the pivot holes in the frames: I guess the holes are drilled to the pivot diameters and then opened out with a broach. My question is how much should they be opened? I have seen books recommending that the arbors should be able to tilt by about 15 deg. but the frame thickness must affect the amount of tilt for a given clearance. What would you recommend?
                Russell.
                #83050
                johnp10
                  @johnp10
                  Hello Russel.
                  I suggest that you drill the pivot holes a few thou. less than the pivot diameter then broach the hole on the inside of the frame plates until the pivot will just fit into the hole. At this stage cut the oil sinks on the outside of the plates, lightly countersinking the holes first to provide a location for the d-bit. Now broach out the pivot holes equally on each side of the frame plate to give about 5 degrees of arbor lean in all directions. Fit the arbour and wheel into the clock frame and check that it spins freely. If it does`nt spin freely or stops with a jerk then one or both holes may be a little too tight. A final check is to fit the arbor and wheel in position then suddenly invert the clock frame When a click should be heard as the arbor drops taking up the end shake.
                  John.
                  #83081
                  Russell Eberhardt
                    Hi John,
                    Thanks for that.
                    Perhaps a silly question but:
                    I had a problem with a clock I repaired where I re-bushed a couple of pivot holes. It would run OK for a few days, then loose half an hour the next day, then run OK again. I found the problem to be that I had made the pivot holes too sharp on the inside edge and the pivots had a significantly rounded corner at the shoulder. This occasionally caused things to stick.
                    Would you recommend an undercut on the shoulder of thee pivot, making polishing difficult or a slight countersink on the inside edge of the holes?
                    Russell.
                    #83170
                    johnp10
                      @johnp10
                      Hello Russell,
                      Machine your pivots with a sharp internal corner and chamfer the arbor at about 60 degrees inc. to about 1 m/m diameter larger than the pivot , then c`sk the pivot hole just a few thou. to remove the sharp corner. This reduces the rubbing friction between the pivot shoulder and the frame plate.
                      John.
                      #83196
                      Russell Eberhardt
                        Russell.
                        #106559
                        Mogens Kilde
                          @mogenskilde92996
                          Hello
                          Could someone (maybe John him self ) tell me the dimension of the main spring, for 15-day clock.
                          I know the part number is stated in the article, but still I would like to know the dimension
                          Thanks in advance
                          Mogens
                          #106579
                          roy entwistle
                            @royentwistle24699
                            Hi The part no's of the suspension and main springs will depend on where they are puchased from
                            Roy
                            #106586
                            Mogens Kilde
                              @mogenskilde92996
                              Hi Roy
                              Thanks for your reply.
                              Exactly… Thats why I would like to know the approximate dimension, and experiment in the work shop
                              Mogens
                              #106597
                              RJW
                                @rjw
                                Mogens, the part number is useless if you don't know the supplier to whom the numbers pertain!
                                If it helps, you will find that when buying mainsprings from a supplier, the dimensions you will use to select them from stock charts are:
                                (a), the internal diameter of the mainspring barrel
                                (b), the working depth of the barrel, which is internal measurement from the bottom of the barrel to the inside face of the barrel cap, you can get away with using a depth gauge using the seat for the cap as a datum!
                                Allow for working clearance inside the barrel when closed, the springs available will probably determine this, too wide and the cap won't fit, so select the size down where it will!
                                (c), the 'Force' or thickness of the spring, this is the main dimension you will need because you already have the others if you have the barrel to hand!
                                Meadows and Passmore usually have a good stock:
                                It's a bit of a faff going from their homepage because there's no direct link to their mainspring listings (robots), but click 'Buy Online' > Enter M&P Store > The Driving Force + enter 'mainsprings' in the search box > this will take you to their mainspring listings, you'll get an idea then of their sizing conventions and increments of dimensions between sizes, it's the same for all of the suppliers I've used.
                                johnp10
                                  @johnp10
                                  Hello Mogens.
                                  Thank you for your query.
                                  The mainspring that you require is available from Meadows & Passmore, Tel 01273 421321.
                                  Part number 0321 204015
                                  Dimensions, 20 x 45 x 45.
                                  This was originally in stainless steel but a look today on M & P website seemed to indicate that is now only available in clock grade steel. This should be satisfactory.
                                  Hope that this helps.
                                  Regards.
                                  John Parslow.
                                  #106604
                                    Russell has a number of progress photos uploaded. Just click on the link under his name on the original post. They demonstrate that clockmaking skill is passed down the generations so perhaps one day the relevant gene will be identified. Thanks for sharing.
                                    #106612
                                    Mogens Kilde
                                      @mogenskilde92996
                                      Thanks to you all, now I can go on with experimenting The last 40 mm dims. is that the outer diameter of the coiled spring when supplied ?
                                      Mogens
                                      #106623
                                      RJW
                                        @rjw
                                        Mogens, the sepc's given of 20 x 45 x 45 are:
                                        20 = 0.20mm which is the thickness or 'Force' of the Spring,
                                        45(1) = 45mm = 'Height' of the spring, which is the depth of the barrel with cap fitted and allowance for working clearance,
                                        45(2) = 45mm = Internal diameter of the mainspring barrel!
                                        The spring will be supplied fully coiled and wired, you will need a mainspring winder to release it from the wire so you can clean and lubricate the spring before fitting, and then to wind the spring again prior to fitting to the barrel.
                                        Note that with both Height and Barrel diameter, for purchasing other sized springs, you will need to check which way round M&P specify those dimensions, I've numbered them 1&2 for the purpose of this reply only, they may be the other way round!
                                        Spring 'diameters' are sized on internal barrel sizes, and have no bearing on the actual diameter  of the coiled spring you will be supplied with, it would depend how tightly M&P wound it before wiring it up!
                                        Although it's most likely it would drop straight into a barrel, you wouldn't want to do that without cleaning any preservative and dust off, then lubing it first!
                                        Hope this makes sense,
                                        Edited By RJW on 17/12/2012 19:35:24
                                        #106625
                                        Mogens Kilde
                                          @mogenskilde92996
                                          Hi John
                                          On the M & P website I find the following for the partnumber 0321 204015 :
                                          HOLE END CLOCK MAINSPRING 20mm x 0.40mm x 40mm You will find other sizes of mainspring in chapter 15. Clock-grade steel.e
                                          I believe this means that the thickness (Force) i 0.4 mm and that the width (barrel height) is approximately 20 mm, this leave the 40mm to be the inside diameter of barrel
                                          Is this correct ?
                                          Mogens
                                          #106629
                                          Russell Eberhardt
                                            I believe the correct measurements are 20 x 0.45 x 45.
                                            The M & P reference is 0321 204515.
                                            Russell
                                            #106646
                                            RJW
                                              @rjw
                                              Morgens, Yes you've got it, the figures Russel has since added are for the corrected mainspring, the decimal point was missing from the sizes in the reply I quoted from, and I never checked M&P's site first to confirm sizes beofre posting, apologies for any confusion!
                                              Mogens Kilde
                                                @mogenskilde92996
                                                Hello folks
                                                Thank you very much, I will go ahead in the workshop.
                                                Wish you all a merry christmas.
                                                Mogens
                                                #106674
                                                johnp10
                                                  @johnp10
                                                  Hello Mogens,
                                                  Yes, that is correct.
                                                  Regards.
                                                  John.
                                                  #106692
                                                  johnp10
                                                    @johnp10
                                                    Hello Morgens,
                                                    Yes, That is correct.
                                                    John.
                                                    #107338
                                                    Mogens Kilde
                                                      @mogenskilde92996
                                                      Hello folks
                                                      Just wanted to show my tool for winding the main spring
                                                      Hope the photos tell the function, otherwise you just ask, I'll be happy to answer
                                                      Regards and a hope for a happy new year to all of you
                                                      Mogens
