Minature Ball Races
Minature Ball Races
Home Forums Clocks and Scientific Instruments Minature Ball Races
  • #45959
    Peter Bell
      @peterbell11509
      Just read some interesting articles about using minature ball races in clocks to reduce friction at the various pivots. See that some high quality clocks (Erwin Sattler?) are quoted as using them everywhere as well as jewels.
      Seems a good idea to me but have never used them before—has anyone tried this and what were the results?
      Peter
      Peter Bell
        @peterbell11509
        #45999
        ColH
          @colh
          Hi John
          I have not tried them myself but I have a copy of an artlicle by a member of the Sydney(Australia) Clockmakers group.
          He ran tests to determine the coeficient of friction (CoF) for a couple of types of ball bearings and a conventional polished pivot.  He did the tests on the bearings as received ie had some sort of lubricating oil in them and then washed them out with kero (parafin to those in the UK) or acetone and ran the tests again.  Results were as follows:
          Plain 1mm pivot – CoF 0.16  dry and 0.22 oiled
          Economy 2mm bearing – CoF 0.0044 as received
                                                     – CoF  0.0023  washed in kero
          Stainless 2mm bearing – CoF 0.019 as received
                                                      – CoF  0.001  washed in kero
          Economy 5mm bearing – CoF 0.0078 washed in kero
                                                      – CoF  0.0014  washed in acetone
          A US supplier of jewled pivots claimed a CoF of 0.15.  Not much better than a plain pivot but would wear much better.
          The author also stated that:
          Results of the Theoretical Study
          With plain pivots, and assuming a pivot C of F of .15, and a gear meshing efficiency of 98%, the losses prior to the escapement are 22%, of which the pivots accounted for 14.8%.
          If ball bearings are used on all arbors and using a pivot C of F of .005, with a gear meshing efficiency still at 98%, the losses prior to the escapement are 11.6%, of which the bearings accounted for only 3.4%.
          If, indeed, the ball bearing C of F is really as low as .001 as some of the tests indicate, then the losses in the pivots would be virtually negligible. So the only losses through to the escape arbor would be due to gear friction, which, at this time, is an unknown quantity even though an efficiency of 98% was assumed.
          As I was not the author I cannot comment on the results but they seem reasonable to me.
          regards  Col
          #46041
          Peter Bell
            @peterbell11509
            Hi Col,
            Thanks for the reply—I have a copy of that article by Rex, also an article by Dick Stephen here in the UK. Both agree and make interesting reading so I am going to use them in my next clock.
            I wonder what the downside is—apart from the cost of buying them!
            Regards  Peter
            #46042
            Peter Bell
              @peterbell11509
              Hi Col,
              Regards  Peter
              #48381
              Richard Stephen
                @richardstephen45588
                Hi All, I only use ball races in all my clocks now . I get mine from SMB Bearings and if possible get the cheaper Chinese ones. These are slightly less orcision and hence have slightly less friction.
                #48399
                ColH
                  @colh
                  Hi Dick
                  How do you mount the bearings?
                  Col
                  #48408
                  Circlip
                    @circlip
                    Usually from the left.
                     Sorry, coat on.
                      Regards  Ian.
                    #48537
                    Richard Stephen
                      Col, I drill a hole through the plate 0.5 mm larger than the pivot diameter. I  thencounter bore the plate to a depth equal to the thickness of the gearing. The diameter of the counter bore should be about 1.5 mm larger than the o.d. of the bearing. I cut off a piece of brass rod bigger than the counter bore Face off the enf and drill and ream a hoe equal to the o.d. of the bearing. Turn down the outside of the brass so that it is a easy fit into the counter bore. Part off a length slightly longer than the thickness of the gearing. Glue the sleeve into the recess using Loctite (326 is best). Clean out all the excess loctite. Use Hamerite solven (Xylene)t to remove the Loctite. File flush with the plate.
                         This may seem a long winded method Try boring a blind hoe in a piece of scrap brass for say a 6 mm bearibg. See if you get an accetable fit. I never have which is why I do the above
                      #48603
                      Peter Bell
                        @peterbell11509
                        Hi All,
                        I have had some success boring blind holes for these bearings. After experimenting  I found that I can  successfully bore a blind hole for a 5mm bearing using my Abene knee mill and a Kurodo boring/facing (same as Wohlhaupter)  head I bought in a sale some years ago.
                        The secret really is being able to line up to the arbour hole using the excellent  centering microscope built to to the Dick Stevens design and the tiny carbide tin coated boring bar from e-bay USA. The Dro’s help and the whole setup looks ridicules really with the size of the machine but it is repeatable and I imagine could be achieved with any boring head  with micrometer adjustment and a good sharp tool—or perhaps I was just lucky!
                        Regards  Peter
