I expect many used the gears that Reeves supplied but they no longer list them. If you can post the spec of the gears eg DP, number of teeth, etc then it will help with suggesting other options.
I've cut governor bevels for other engines, they don't need to be exact as there is no real load
Edited By JasonB on 08/09/2022 13:28:19
