David
First take look at **LINK** and verify whether yours is a MK 1 with the 3 speed motor or a MK 2 VSL with single speed motor and variable speed belt drive. I don't know when the MK2 VSL version of the 1024 was introduced but late 1970's has the right feel. If it is a MK2 life is much, much easier.
A static converter will still struggle on a MK2 because there is no clutch so it has to run up the spindle and drive every time. Simply adding a pilot motor should sort that.
Talk to Transwave, they are helpful folk and have the experience to know the best way to drive whichever motor you have.
In similar circumstances on another breed of machine, albeit with a two speed rather than three speed motor, simply adding a 5 HP pilot motor to a 4KW static converter got things running well enough. That was a MotoRun converter but a Transwave is essentially similar.
I run my 1024 VSL off a 220 V in / 440 V out VFD box from Drives Direct. Mine is 10 HP "whole shop" unit permanently set to 50 Hz and runs everything a treat. Very expensive but, so far as the machines are concerned its proper 3 phase from the grid. A smaller, single machine, VFD works fine on the VSL too but you do need to re-jig the controls to operate the VFD direct.
I suggest you sign up with the Smart & Brown group on Yahoo as there are members with direct experience of setting up static or rotary converters on the 1024.
Clive.
Edited By Clive Foster on 16/09/2017 18:05:51
