Beer engine
Beer engine
Home Forums The Tea Room Beer engine
  • #262010
    Mark P.
      @markp
      http://www.model-engineer.co.uk/wp-content/uploads/sites/4/images/member_albums/50081/thumbs/700419.jpg
      Just been asked to make adapter plates to fit beer taps to a Lancia elgine block. I will go on the bar in his pub.
      Mark P.
      Mark P.
        @markp
        #262028
            Looks like a Cider engine to me
            … especially as it's already fallen over.
            Mark P.
              @markp
              Thanks for sorting out the photo Neil. I think it may have had one or two Michael!
              What you can’t see is the inch thick plate with an 11 degree taper between the head and manifold to bring the taps horizontal,just needs polishing.
              Mark P.
              #262051
                Interestingly the Exif information says the image should be rotated…
                I think the problem when this happens is people (or the camera) turn them the 'right way up' in a way that doesn't actually rotate the file.
                  Graham Titman
                    @grahamtitman81812
                    You want the proper stuff not the commercial rubbish.A small farm in the heart of Gloucestershire a single track road you sit there quietly sipping your glass until he has blended it to your taste from three massive vats at the end of the bar,he then fills up your 5 gallon barrel and you get up and realize you could be very close to the drink drive limit.
                    #262248
                      Does seem a shame to put strongbow in it
                      I remember The Halfway Inn between Aberystwyth and Rheidol Falls. It was serve yourself straight from the barrel, often with perry and cider as well as real ale. Around 84 hey fitted bars to the taps because some people couldn't turn off taps that just kept going round and round!
                      N.
                      #262261
                      Mark P.
                        @markp
                        The Strongbow tap was the only tap he had spare. Should be pumping Italian soon.
                        Mark P.
                        #262265
                        Dave Halford
                          @davehalford22513
                          try and keep it clean
                          #262371
                          Yngvar F
                            @yngvarf
                            Just adding a beer amp I just finished.
                            Six taps on the back.
                            img_0779.jpgimg_0821.jpgAnd some handles and label holders too add some machining,.
                            #262467
                            John Olsen
                              @johnolsen79199
                              I suppose it is a valve amplifier?
                              #262507
                                Does it go up to 11%?
                                N.
