Can you identify this motorcycle?
Home Forums Related Hobbies including Vehicle Restoration Can you identify this motorcycle?
Viewing 25 posts - 1 through 25 (of 45 total)
  • #581967
    Anonymous
      This post has been removed at the author’s request.
      Anonymous
        #581972
          Former Member
            @formermember12892
            #581976
            Anonymous
              #581982
              Andrew Tinsley
                @andrewtinsley63637
                Looks like my father's pre war James 198cc twinport.
                Andrew.
                #581983
                Mark Rand
                  @markrand96270
                  There were an awful lot of M20s made over nearly 20 years, in both military and civilian versions, so there was a fair bit of variation.
                  #581985
                    Is there a certificated Rivet-Counter on the forum ?
                    … We need your assistance:
                    Former Member
                      @formermember12892
                      #581988
                      Steviegtr
                        @steviegtr
                        There was also a M21 600cc version. Or could it be an Aerial. ?? really no idea .
                        #581990
                        Anonymous
                          #581996
                          duncan webster 1
                            @duncanwebster1
                            Looks a lot like a BSA C10, I had one once, horrible thing
                            #581997
                            JohnF
                              @johnf59703
                              My observations are it appears have a solid frame and girder forks so most probable pre war or at least pre 1950 I think, Had a short search and a BSA C10 c1939 seems a possibility, the timing cover looks similar and its a side valve engine [C10 was made for several years well into the 50's with tele forks] See a couple of links
                              https://www.feked.com/images/detailed/32/IMG_4849-1000.jpg
                              https://classic-motorbikes.net/wp-content/uploads/2015/10/9092.jpg
                              edit — Ha! Duncan beat me to it
                              Edited By JohnF on 23/01/2022 20:53:30
                              #581998
                              Chris Evans 6
                                @chrisevans6
                                Another vote for sidevalve BSA C10.
                                Second thoughts the girder fork side links don't look like BSA.
                                Edited By Chris Evans 6 on 23/01/2022 20:59:40
                                #581999
                                Anonymous
                                  #582000
                                  Robert Butler
                                    @robertbutler92161
                                    The OP image does not show access to the valve chest so unlikely to be a C10. I am inclined more to the two stroke theory.
                                    Robert Butler
                                    #582011
                                    Bill Pudney
                                      @billpudney37759
                                      Whatever it is, or isn't, it's what used to be described by "One Track", in Motorcycle Sport as "….grey porridge…."
                                      cheers
                                      Bill
                                      #582015
                                      Robert Butler
                                        @robertbutler92161
                                        Also no sign of an oil tank and most 4 strokes of that era are dry sump.
                                        Robert Butler
                                        #582017
                                        Ex contributor
                                          @mgnbuk
                                          Carb mounts at the top of the cylinder, so unlikely to be a two stroke.
                                          No idea of the maker though.
                                          Nigel B.
                                          #582020
                                            Robert Butler
                                              @robertbutler92161
                                              May be, but carb may not be bolted directly to cylinder, may be a manifold or downdraft mounting. The puzzle is there appears to be a timing chest or it could be a mag dyno drive?? The no oil tank is a pointer to 2 stroke. The Classic Motorcycle – Richard Rosenthal expert on old motorcycles.
                                              Robert Butler
                                              #582022
                                                Posted by Robert Butler on 23/01/2022 22:52:05:
                                                Please see opening paragraph … here: **LINK**
                                                https://www.cyclechaos.com/wiki/BSA_C10
                                                Robert Butler
                                                  @robertbutler92161
                                                  Michael, the OP image shows the engine fitted with an alloy cylinder head whereas the catalogue shows an iron head. The catalogue shows what appears to be a tool box on the off side and yet other images on the web show an oil tank for the dry sump lubrication on the offside where you would expect it to be located.
                                                  Robert
                                                  #582025
                                                  Robert Butler
                                                    @robertbutler92161
                                                    However other images show either an alloy cylinder head or one finished in silver?
                                                    Robert Butler
                                                    #582026
                                                    Fowlers Fury
                                                      @fowlersfury
                                                      This is it surely:-
