RPi (or something) to connect to VPS over OpenVPN
Home Forums Related Hobbies including Vehicle Restoration RPi (or something) to connect to VPS over OpenVPN
  • #521898
    simondavies3
      @simondavies3
      Hi All,
      I am hoping that the collective wisdom on the forum will be able to aid me towards my goal of having a gateway between some of my network components in the house and my VPS running OpenVPN based in the UK.
      I think I need to have a RPi or something similar to run OpenVPN and connect to the VPS as I have other equipment doing directly (e.g. iPads) on one side and have a router like connection on the other side. However I am at the limit (beyond the limit?) of my knowledge, especially on RPis.
      Most of the equipment I want to connect through the VPS are unable to run OpenVPN clients or even install them, hence the logic in taking the VPN access one step closer to the VPS.
      I am emphatically not looking to do an R&D project here, anything available off the shelf will also be of great interest. Equally if I can connect a set of existing components or follow someone else's route I would be happy to do that – but I am lacking in the initial knowledge and ideas where to look.
      Thanks in advance for any helpful suggestions!
      Simon
      simondavies3
        @simondavies3
        Gateway for VPN use
        #521911
        Peter Spink
          @peterspink21088
          I've been running a Pi with Open VPN for a couple of years.
          Got all my info from here: **LINK**
          #521929
          simondavies3
            @simondavies3
            Peter, thank you, I think that this is what I need. Just need to get my head around the details and find a Rpi.
            simon
            #524409
            simondavies3
              @simondavies3
              Peter,
              I now have an Apple TV operating behind a headless Raspberry Pi operating as a VPN client – a very successful, if rather steep learning curve first dip into Linux.
              The links were helpful but not exactly what I needed, they gave me the vocabulary to search for the eventual solution. For the benefit of anyone else searching, the two key links were:
              RPi VPN gateway
              which helped me to install and setup the RPi and:
              Routing and NAT
              which helped setup the critical routing, firewall and NAT settings.
              Regards, Simon
              #524420
              Peter Spink
                @peterspink21088
                Great stuff, glad you're sorted! yes
