Hi All, I frequent autojumbles, looking for stuff for my '50s AMC singles. A while ago I picked up a +60 piston, sans rings, always useful to have in reserve. I recently found a set of +60 rings for a fiver, but although the 2 compression rings fit, the oil control ring is a couple of thou too deep top to bottom. I have a book from the 30s that describes how to make piston rings on a lathe, but it is a lot of hassle. I thought a simpler way would be to put the ring on a surface grinder and take a thou or so off top and bottom faces. I might be able to do this at the local tech college, or pay an engineering firm. Any thoughts? Cheers, Andrew
