aluminium crank cases
  • #34351
    gerry madden
      @gerrymadden53711
      gerry madden
        @gerrymadden53711
        Hi, I have some aluminium crank cases from a small engine that have been in a damp environment for a few years and have developed that patchy white dusty coating.
        I'm sure it will rub off with a bit of effort but I'm just wondering if there is a much more efficient way of cleaning these things up without leaving abrasive scratching marks in all different directions ?
        Gerry
        #301805
        Jeff Dayman
          @jeffdayman43397
          You might try a motorcycle engine repair shop for glass bead blasting. It will leave a nice clean matte finish on your aluminum and not mar any details or leave scratches.
          A coat of good clear car wax afterward, or some clear urethane spray clearcoat on outer surfaces, will keep the parts looking nice. JD
          #301806
            Gerry,
            The best way that I have found is to use a GaryFlex block [which is rather like the old school 'ink rubbers'], with Solvol Autosol polish as 'lubricant'.
            Yes, it's abrasive … but very mildly so.
            Involute Curve
              @involutecurve
              I vapour blast all my crankcases as a matter of course, the finsih is as new, but you must make sure you clean all oilways etc afterwoods.
              Shaun
              #301832
                I used my ultrasonic cleaning tank with a 'sensitive metals corrosion remover'. Not obvious from these shots, but it removed white 'bloom' as well.
                #301845
                Ian Skeldon 2
                  @ianskeldon2
                  DO NOT USE OVEN CLEANER,
                  and don't ask me how I know wink
                  #301850
                  ronan walsh
                    @ronanwalsh98054
                    I boiled up some old cases in water with normal washing powder in it, the cases came out like new. But i tried it with a separate set of case sometime later, and they came out a blackish grey colour, not nice at all. Someone said it was because of the silicon content of the aluminium reacting with the contents of the powder.
                    #301854
                    thaiguzzi
                      @thaiguzzi
                      Posted by Involute Curve on 09/06/2017 17:33:22:
                      Shaun
                      +1. Wot he said.
                      There is no better finish.
                      #301894
                      Tim Stevens
                        @timstevens64731
                        Ronan is correct – some Aluminium alloys contain a high proportion of silicon, and when the Al is eaten away (by eg washing soda, or worse, caustic soda) the Si is left as dirty smudges. This is a major reason why anodising does not give good results on such alloys.
                        Aluminium does not rust
                        It crumbles to a greyish dust
                        And most of all what you can see
                        Consists of Al two O three
                        Cheers, Tim
                        #302006
                        gerry madden
                          @gerrymadden53711
                          Well as usual some great info there. I didn't know about vapour blasting did some research and I'm impressed ! What's more there's a small business not far away from me that does it so I'll be visiting them next week. And by the looks of it, there's quite a few more bits and pieces they can do besides my crank cases.
                          Thanks all for your input.
                          Gerry
