How to test dc motor or board?
Home Forums Help and Assistance! (Offered or Wanted) How to test dc motor or board?
  • #493945
    Gerard O’Toole
      @gerardotoole60348
      The motor on my Chinese lathe has stopped working. All lights come on etc. but the motor fails to turn . I am assuming that either the motor or the control board is at fault. I have checked all wiring etc. for any loose connections and also the fuse.
      My electical knowledge is limited but my understanding is that the dc motor should run from a 12v battery. It is a normal brushed motor . Could anyone confirm, if this is the case and can i just connect the two wires from the motor to a suitable battery? i have 6V and 12 V motorcycle batteries available.
      I have tried to attach photograhs but not sure if that worked
      Thanks for any help
      Control boards
      motor
      Gerard O’Toole
        @gerardotoole60348
        Lathe motor not turning
        #493950
          Hi Gerald,
          Links to photos work for me.
          Yes, just connect the motor to a 12v battery. Although the motor normally runs at 110vdc, it should turn slowly on a 12v battery. Disconnect the motor from the control board to do the test.
          The control board can be tested by connecting a 240vac filament light bulb to the output. Any wattage will do. The bulb will light dimly, and its brightness should go up and down with the speed control. Filament bulbs are thin on the ground these days because they're being replaced by modern energy saving lamps which are no good this test. However, Oven Lamps are 240Vac filament.
          Take care doing the test. Although the controller only outputs 110v it hurts! Keep away from the circuit board when mains is connected.
          Another possibility: the potentiometers used to control speed are vulnerable to dirt and wear. The centre wiper disconnects from the resistive track and the controller stops working. Cure is to replace the pot, cost a few pounds.
          A faulty pot normally develops over time with erratic speed control or dead spots as the knob is turned. If the lathe failed suddenly whilst working hard, most likely the control board failed, in which case confirm with the light bulb test.
          The motors are fairly robust unless made too hot by overwork. Worth inspecting the brushes to see they're not worn out.
          Ex contributor
            @mgnbuk
            I tested that the motor of a Chester mini lathe I bought without a control board from one of their open days using a 12v car battery – it ran smoothly. As my lathe had no board fitted, the motor leads were directly accessible without any disconnection required.
            IIRC the OE motors are 180v DC, so the motor should run at 1/15th maximum speed @ 12V, as speed is proportional to voltage applied for a PM DC motor.
            Nigel B
            #493964
            Gerard O’Toole
              @gerardotoole60348
              Thanks Dave, Nigel
              i have most of the covers etc. removed so I will try the battery test and report back.
              thanks for the help
              gerard
              #493972
                Before spending a lot of money, have you checked the brushes (Assuming that it it has brushes )?
                #493983
                Gerard O’Toole
                  @gerardotoole60348
                  i have done the battery test and the motor runs slowly with 12 volts. ( I haven't disconnect the belt drive so it is still driving the spindle and leadscrew). I video'd the motor working and link is here https://photos.app.goo.gl/4sUnL29fCav6GtU97
                  I have also taken out the brushes and they seem fine.
                  Done the light bulb check and no light. ( and I checked that the bulb is good) .
                  There is a potentiometer , red green and black wires.
                  In the lowest (Off) position I measured R-B 4.5 Ohm, RG 0 Ohm BG 4.5 Ohm
                  In the highest(fastest) position I measured R-B 0 Ohm, RG 4.5 Ohm BG 4.5 Ohm
                  So it looks like a faulty board. I will contact the vendor and try to get a replacement
                  Thanks for all the help. Really appreciated it
                  gerard
                  #494015
                  Gerard O’Toole
                    @gerardotoole60348
                    Another thing I noticed, the fuse is on the neutral wire rather than the live. Surely this is not correct?
                    Again a photograph is here:-
                    https://photos.app.goo.gl/L3EUa3MkUr8131hv5
                    gerard
                    #494058
                    Grizzly bear
                      @grizzlybear
                      Gerald,
                      Have you examined the underside of the board for dry joints or burnt copper tracks?
                      A magnifying glass is a good aid.
                      Good luck, Bear..
                      #494125
                      Gerard O’Toole
                        @gerardotoole60348
                        Thanks Bear
                        I will do so.
                        Gerard
                        #494135
                        Robert Atkinson 2
                          @robertatkinson2
                          Posted by Gerard O'Toole on 03/09/2020 14:50:31:
                          gerard
                          The fuse should be in the LIVE connection. Puttting it in the neutral is unsafe for two reasons.
                          /1 Most importanly but not obvious, if the fuse fails or is removed, even without a fault, it leaves the machine "dead" but with ll the circuits up to the fuse still live and waiting to shock or electrocute someone investigating.
                          2/ it does not protect against a short to ground inside the machine. This means the internal wiring or components could overheat or catch fire as they may not be rated to take the (more than) 13A the plug fuse will supply.
                          You should re-wire the fuse to the positive supply. What brand is the machine? bought direct from China or UK seller?
                          Robert G8RPI.
                          Edited By Robert Atkinson 2 on 04/09/2020 08:29:07
                          #494157
                          Gerard O’Toole
                            @gerardotoole60348
                            Thanks Robert
                            I was surprised to find the fuse like this. I will reconnect it onto the live side.
                            I will also have a good look for any weak soldered joints although i now have, hopefully, a replacement board on its way.
                            regards
                            Gerard
                            #495898
                            Gerard O’Toole
                              @gerardotoole60348
                              Sorry for reopening this thread,
                              I have a replacement board, identical to the old one, and i am about to fit it.
                              As I mentioned, the fuse is fitted to the neutral wire instead of the live wire and I know that needs to be changed..
                              But also, the live wire is going to the "N" pin on the board and the neutral wire is going to the "L" terminal. . I have traced the wiring and is shown in this diagramwiringdiagram_ actual.jpg
                              But the lathe worked okay with the Live and Neutral wire connected wrongly. Would that be possible that the board would work with the live and neutral wire reversed? And do i risk causing more damage 'correcting ' this?
                              The manual shows the wiring diagram as this
                              Thanks for any help.
                              Sorry for posting so many photographs
                              Gerard
                              #495901
                              Gerard O’Toole
                                @gerardotoole60348
                                Sorry, duplicate post
                                Edited By Gerard O’Toole on 15/09/2020 11:55:51
                                #654666
                                Peter Jones
                                  @peterjones49190
                                  To let ypou know the Chinese milling and lathe of this type actually wire the L and N the other way round on the milling machine here is the same (L on N terminal and N on the L Terminal) which actually matches the wiring diagram. I though the wring diagram was wrong until I check what was really connected, it will work and is supplied by the factory that way round. I assume that some had printed the PCB's wrongly, but instead of throwing them away, they just altered the diagram to match.
                                  #654725
                                  Robert Atkinson 2
                                    @robertatkinson2
                                    Regardless of how the board is marked or wired, it is most important that the fuse and main switch are in the live of the incoming connection.
                                    This is because if they are in the neutral and the fuse blows or the switch is off the machine will appear dead but all the internal wiring up to the fuse or switch will be live and waiting to shock anyone working on the machine.
                                    Robert.
                                    #654738
                                      Posted by Peter Jones on 01/08/2023 10:04:07:
                                      It works either way round because the input is an alternating current. In terms of electrical function there is no difference between Live and Neutral, because they operate as a pair. But don't do it!
                                      The important difference is safety.
                                      Electricity suppliers make the system safer by ensuring that one wire is earthed, rendering it Neutral, that is at the same potential as anyone on the ground who touches it. No shock.
                                      The other wire remains 'Live' and is dangerous. It coming loose and touching the metal chassis would turn the equipment into a widow-maker, except all exterior metalwork should be connected to earth, which instantly blows the fuse.
                                      Fusing the neutral wire stops electrical fires, but it doesn't disconnect the live side, so the equipment is still a shock hazard. It fails dangerous. Then Mr Innocent opens the box and pokes around inside, wrongly assuming that the equipment has failed safe, and it isn't. To be safe the fuse must be fitted to the live wire, not the neutral.
                                      General rule is to always unplug electrical equipment before going inside. Don't trust fuses at all! If essential to debug a live circuit, assume the worst and take every precaution. A few electricians are killed every year despite their training. Even when you understand, it's easy to make a mistake.
                                      Master of none
                                        @masterofnone
                                        Could I suggest that your refer to the "live" conductor as the "line". The neutral is connected to the supply transformer as well as being earthed, so technically, it is also a live conductor.
