Stuart 10H Hard spots in a casting
Home Forums Stationary engines Stuart 10H Hard spots in a casting
  • #344736
    Jon Lawes
      @jonlawes51698
      Can I please ask how many hard spots a casting can have before you consider it unusable? I'm trying to sort out the box bed for my Stuart 10H and I'm struggling as the file just glides over hard shiny sections and makes cutting it really difficult. I've emailed Stuart and await their response.
      Cheers,
      Jon.
      Jon Lawes
        @jonlawes51698
        How much is too much?
        #344740
        Chris Evans 6
          @chrisevans6
          If I get "Chilled Spots" in cast iron it usually spends a night in the wood burning stove and comes out OK to machine. Even SWMBO never notices.
          #344742
          roy entwistle
            @royentwistle24699
            +1 for Chris's answer
            Roy
            #344743
              Stuarts are usually quite good about replacing so wait to you hear back from them before cooking it.
              #344744
              Jon Lawes
                @jonlawes51698
                I don't have a wood burning stove; I guess a night on a radiator just wont cut it! laugh
                #344745
                  Propane torch may just do it, that is what I usually use
                  #344755
                  Jon Lawes
                    @jonlawes51698
                    That has potential; I'll see what Stuart say. I have already taken a couple of cuts so hopefully I haven't weakend it too much.
                    #344766
                    Jens Eirik Skogstad 1
                      @jenseirikskogstad1
                      See this link: http://www.homews.co.uk/page215.html
                      Edited By Jens Eirik Skogstad on 06/03/2018 21:33:24
                      #344780
                        Suggesting a tipped tool will be OK for facing the surface but you are still stuffed when it comes to drilling and tapping fixing holes if the hard spot is any more than surface chill.
                        #345383
                        Jon Lawes
                          @jonlawes51698
                          They have said they will send me a replacement with no quibbling at all. I was a bit worried what their customer service would be like after my original order took some months to arrive but they seem to have good after care.
                          #345440
                          mechman48
                            @mechman48
                            Posted by JasonB on 06/03/2018 19:50:50:
                            ​I had a similar problem with the standard for my S10 V some time ago I mentioned this to Stuarts at the last Harrogate ME exhib. they promptly sent me a replacement…+ 1 for stuarts.
                            George.
                            #349106
                            Jon Lawes
                              @jonlawes51698
                              Nothing arrived yet, a month after being told they would send out a replacement. After a delay of over 6 weeks between paying for the kit and it actually turning up I guess Stuart run a fairly slow moving business. Frustrating, but I understand how low volume manufacturers work.
                              #349116
                              IanT
                                @iant
                                Hi Jon,
                                I don't have a wood-burning stove either but (as I've mentioned elsewhere here recently) – I do have a garden incinerator.
                                I compost or 'brown-bin' my soft cuttings but any 'wood' is dried out, cut or chopped up and burnt in the incinerator. I wait till I have a bright fire going (with a red-hot ash bed) and lower the part(s) in to rest on top. I then keep feeding the fire for an hour or so and then let it burn overnight with the lid on.
                                Next day, there will still be hot ashes in the bottom and the parts will still be pretty warm but the wood fire doesn't get hot enough to damage any steel/cast iron parts. I did once try wrapping a part in kitchen foil to help keep it clean – but the foil melted. So aluminium parts/castings may get damaged doing this but wouldn't benefit from any heat treatment anyway. But for hard spots in castings and for de-stressing steel parts this seems to work OK though… I will eventually get around to trying case-hardening in it as well…
                                IanT
                                #349869
                                Jon Lawes
                                  @jonlawes51698
                                  After chasing them a couple of days ago its turned up today. Looks excellent as always.
                                Home Forums Stationary engines Topics
