Duncan, there are several designs that use an eccentric such as Penn's which I mentioned earlier. But this one does not use an eccentric there are a few ways these were arranged, in this case there is a STRAIGHT channel much like on Joy or Hackworth valve gear but the rocking motion of the valve chest provides the main source of movement not an eccentric.
The only thing I can't see is an actual reversing lever for the operator to select direction.
This is one example without an eccentric but as the pivot is fixed off to one side of the pivot point the engine can't be reversed, also better suited to end pivoting rather than middle. Valve gear closeup at about 1min in.
And this is Elmers No 42 which is close to whats needed but not reversible
Edited By JasonB on 02/08/2016 07:44:09
