ST beam engine
ST beam engine
Home Forums Stationary engines ST beam engine
  • #236269
    phil burley
      @philburley12227
      Hello , I am building a Stuart Turner beam engine , I have got to the eccentric Andrew Smith's book says make it off centre by11/64 but the drawing says 9/64. Can anyone tell me which is correct please
      Regards Phil
      phil burley
        @philburley12227
        #236270
        RICHARD GREEN 2
          @richardgreen2
          I didn.t know Andrew Smith was eccentric ! smiley
          #236273
          BC Prof
            @bcprof
            I am pleased that you could read the drawings in the book . Mine was too badly printed to do so.
            Mk 1 eyeball gave me 5mm eccentric ( 10mm throw ) with a 14 mm between centres operating arm.
            If you find that the throw is too big you can easily adjust the length of the operating arm .
            Brian C
            #236274
            Ian S C
              @iansc
              Might have missed a comma.
              Ian S C
              #236276
              phil burley
                @philburley12227
                true sorry !!!!!
                phil
                #236280
                phil burley
                  @philburley12227
                  oh yes I see . I could alter the length on the rocking lever to get it right if needed
                  thanks Phil
                  #246112
                  Billy Bean
                    @billybean67480
                    Same query – Stuart advise 9/16 is correct.
                    My Stuart drawings that came with the castings shows 11/16.
                    #246113
                      Mine seems to run OK on 9/32nds movement (9/64" off ctr)
                      9/16" would put the hole outside the eccentric
                      Edited By JasonB on 10/07/2016 15:08:36
                      #246117
                      Billy Bean
                        @billybean67480
                        Apologies – senior moment.
                        9/16 and 11/16 should read 9/64 and 11/64
                        Jason is correct, 9/64 is what Stuart confirmed – they did say that the drawing was incorrectly dimensioned at 11/64.
                      Home Forums Stationary engines Topics
