Thanks folks.
Before I check out your links, I explored my heat engines book in bed last night. The valve is a throttle – a form of governor. It also lists the patent numbers and dates… sorry for making you all work so hard
The patent is interesting, the section doesn't show a water passage. The throttle valve is governor operated, something I have never seen made. It does, however, detail a gas jet and even a chimney arrangement.
That section of a later engine is excellent, the only detail difference being a water passage between the transfer passage and the displacer rod – but is that box a water reservoir or a guard for the flywheel? The latter seems unlikely.
Most striking is that the displacer/regenerator is a close fit in the upper part of the displacer.
Also nice to see an 1880 example in action.
Much food for thought, thanks all.
Edited By Neil Wyatt on 02/03/2016 10:23:34
