I want to make a scroll saw for thin metals, grp sheet, ply & balsa ( model aero building).
I would appreciate comments on the following:-
1) How many oscillations per minute do forumites reckon I need. I will have a simple eccentric & the number of revolutions will govern the number of times the blade goes up & down.
2) How far up & down would you reckon the blade should travel. This will govern the size of eccentric. is 20mm enough or too much? Should it be faster & less stroke length or slower & a longer cut. Presumably the upper spring will have to adjust to this & thus govern the stroke. But it must affect operation somehow
3) I seem to recall a standard single phase motor of about 0.25 HP runs at 1450 RPM. Is that correct? & any ideas where I can source one cheap?
4) I will cut the gears from tufnol as I have only just bought the lathe & mill ( Promised delivery Friday– Hurrah!!!) so I want to go easy on the cutters.
So how big should the teeth be. I know the ratio is set by number of teeth to number of teeth but should I be looking at very small teeth. How does one decide on tooth size on gears . Is there a table somewhere that one follows. Would smaller teeth be better on tufnol ? Bigger may be easier/ quicker but will the tooth snap off? should I have small teeth for quieter running or will they just strip off?. Or is it decided by the divisions available on the dividing head?
Finally – No; I do not want to buy one. Half the fun is making it ones self
