JH. Yes im well aware of the neat wiring trick you refer to , that gives reverse by a switch .i have a motor like that so i do understand what you are saying, also im inclined to agree because its a modern looking motor, and wouldnt be cost effective to make any other way. i dont think its obvious there isn`t an internal capacitor , i thought that about the compton / parkinson motor i have and i was surprised to see the capacitor inside the motor end cap ( i pulled it apart cos i thought by the way it was running i was thinking lack of capacitor was causing the problem ).turned out be some thing completely different ! The motor i have that runs either way is designed to do so by the way the mechanical centrifugal switch is configured and a extra contact, so when the motors at rest its going to be in the either this way or that way position. This motor used to my granddads and dates to about end W1 maybe early 1920s. Funny thing is it was only 7/8 years ago i figured out it was a run either way. Just thought one day ill have look see if its a goer, so plugged it in switched in on & off a couple of time and thats when i realized it didnt always go round the same way ! Anyway it was coming apart, to clear dust /cobwebs an the like and to check wiring and insulation , thats when i discovered the strange c/f switch and extra contact ! So on this motor, at least, it does matter what position its in, unless you spin it first !
tbh with the motor in op pics i would have thought it was worth doing search on google for any info
b.
thinking about it, the old granddad used it as grinder , and he always used to give the wheel a flick then turn power on!
Edited By bodge on 09/01/2016 13:27:20
Edited By bodge on 09/01/2016 13:37:47
