Hello all,
I wanted a cutter that I could use for one-pass facing on my milling machine. I thought a cutter that's simple to set up and would face anything hard or soft under 4" would be a useful workhorse. I saw this 5-tip 100mm cutter and it was only a tenner so worth a go. I still need a MT3 arbor but that shouldn't be too difficult to find.
I thought I could get one type of insert that would be OK for general work in steel and aluminium. I bought it without inserts thinking it'd be a doddle to find the right ones. Of course I was wrong. I've wasted hours searching the web and the seemingly billions of inserts out there.
I had some 17mm x 4.5mm inserts which seemed to fit well but you can see from this that the geometry of the cutter as presented to the workpiece is all wrong. There are more pictures in my album. The dimensions you see in the picture are in mm.
So I presumed I wanted inserts of approximately 19mm that would present a cutting angle which would drop the cutting edge below the back edge. Hopefully with the pictures that is clear enough – I'm obviously no expert in the correct terminology! I think it should look like this:
But I cannot find any that appear to be the right size. There are millions of 16mm and 22mm inserts but apparently little in between.
Can anybody please tell me what type of inserts would suit the cutter and hence what designation to search for?
And is my thinking logical – is this cutter suitable for general facing work in my Steinel SV4 milling machine?
Any advice or solution would be gratefully received.
Steve
