Carbon Fibre tube supplier?
Home Forums Help and Assistance! (Offered or Wanted) Carbon Fibre tube supplier?
  • #199355
    Stuart Bridger
      @stuartbridger82290
      Friedn of mine is looking for a carbon fibre tube 1.6m long by 400mm dia. Astronomy application, any ideas of suppliers?
      Stuart
      Stuart Bridger
        @stuartbridger82290
        #199361
        Ralph H
          @ralphh
          Try Hardy's and Grey's Ltd http://www.hardyfishing.com/en-gb/home/
          or Attwater and Sons http://www.attwater.com/.
          I can recommend both as they are suppliers to the firm I work for.They should be be able to advise you on a solution.
          Edited By Ralph H on 05/08/2015 22:19:38
          #199362
          Ian P
            @ianp
            By coincidence 10 minutes ago I sent an email for a quote for a c/f tube. Its a company I have bought custom tubes from for several years now and have always been very satisfied. (no connection to me)
            They are http://www.Tri-cast.co.uk
            Ian P
            #199363
            Ian P
              @ianp
              Posted by Ian Phillips on 05/08/2015 22:27:30:
              Ian P
              PS I think they do up to 1m diameter at least
              #199364
              Keith Long
                @keithlong89920
                That's a serious bit of composite tubing – your friend will likely need deep pockets. Is carbon fibre necessary, would glass fibre do the job?
                I would guess you'd be looking at a custom made tube, either filament wound or laid up from pre-preg sheet, if you can find a company that bcan do that sort of size you might have to alter the diameter a bit to make use of an existing former, a custom mandrel wouild be very expensive – ours were and they were only about 150mm diameter.and shorter than you're looking for.
                #199370
                  Posted by Keith Long on 05/08/2015 22:32:56:
                  … Is carbon fibre necessary, would glass fibre do the job?
                  Keith,
                  If it's for a telescope OTA, then carbon's near-zero coefficient of thermal expansion is very desirable.
                  Keith Long
                    @keithlong89920
                    I fully realised that Michael
                    #199382
                    Stuart Bridger
                      @stuartbridger82290
                      Thanks for the suggestions
                      #199394
                        Posted by Keith Long on 05/08/2015 23:10:13:
                        My apologies, Keith … no slight intended.
                        It's only a fine line between 'necessary' and 'very desirable'
                          Stuart,
                          It's interesting to see that Orion Optics is using 'sandwich construction'
                          … 'though I'm not aware what core material is used.
                          See also, this page from DreamScopes
                          Edit: This might be of interest.
                          Edited By Michael Gilligan on 06/08/2015 06:21:39
                          Edited By Michael Gilligan on 06/08/2015 06:28:46
                          #199408
                            Posted by Michael Gilligan on 06/08/2015 06:18:40:
                            Stuart,
                            Oops … that link seems to be wrong … Try this
                            #199410
                            Ian P
                              @ianp
                              Stuart
                              Would 372.97mm internal diameter be big enough?
                              I have a list of mandrel sizes that Tri-cast use and this one at 900mm long seems to be the nearest.
                              Wall thickness can be whatever you want, most of mine have been between 3 and 6mm
                              Ian P
                              #199427
                              Circlip
                                @circlip
                                Would think the "Meat" is either honeycomb or extruded (Blue) foam.
                                Regards Ian.
                                #199487
                                  Posted by Circlip on 06/08/2015 11:16:28:
                                  Regards Ian.
                                  Very likely, Ian
                                  I should probably have been more explicit, and written:
                                  "… 'though I'm not aware what core material is used by Orion in these particular tubes."
                                  Nick_G
                                    @nick_g
                                    There is a company in Runcorn called Sigmatex. (I did some work for them back in my sparking days)
                                    They weave CF in a large number of widths and weights from something resembling fine silk to course mesh. I remember them telling me at the time that they supplied 90% of the F1 teams and a number of aircraft manufacturers. I also remember them telling me that it was also used to produce helicopter blades and to do this the weave layers were placed in varying directions and a mixture of course and fine fabrics.
                                    They seemed quite open and approachable people. You may be able to purchase a 'roll end' off them and combined with a former make your own. ….. Possibly.!
                                    Failing that, I would be surprised if they were not able to point you in the right direction of such a tube supplier.
                                    Regards, Nick
                                    #199495
                                      Suitable tubes are available here
                                      … wrong side of the pond, I presume.
                                      crying
