Posted by Bandersnatch on 08/07/2015 22:01:38:
This is a 10-32 thread? I ask, because within the small UN series, #10 is somewhat oddball.
Moreover all the #10-32 and M5-0.8 hardware that I have on hand (quite a bit actually) goes together easily either way round (by finger pressure, Michael – I'd assumed anyone here wouldn't get heavy with it)…. not that any of them are UNC Class-3 threads but then, I don't see why Sherline would have used Class-3 threads for something like this either.
I can't speak for Sherline, but I have certainly used quite a lot of 10-32 fixings … typically on Defence equipment, and on the standard mounting threads for [vibration test] accelerometers.
As previously mentioned, the last few seconds of the video that I linked clearly show one insert that was pulled out by attempting to use a tight-fitting M5 screw in a [presumably good] 10-32 thread … yet the early part of the video demonstrates how easily another insert in the same item was re-tapped to M5.
With due respect to your suppliers … May I suggest that you check the actual dimensions of your M5 threads?
Returning to Sherline: Given that these are small fixings on a milling table, I would hope and expect them to be a good class of fit; exactly as our OP has found.
MichaelG. . [UK]
P.S. — Although the choice of 10-32 into Aluminiun Alloy may raise the odd eyebrow; bear in mind that the root diameter of a 10-32 male thread is usefully greater than a 10-24 [and is quite 'safe' in a decent grade of alloy]
Edited By Michael Gilligan on 08/07/2015 22:28:56
Edited By Michael Gilligan on 08/07/2015 22:48:19
