Many thanks for replies…..
I did take the cross slide off to have a look but still unable to move anything.
undid the 4 allen head screws on top of the Apron Assembly and that seperated the assembly just enough to allow me to move the power cross feed lever and also freed up the half nut lever. everything moved freely after that.
Put everything back and then looked at why Leadscrew was not rotating.
As Mike said the Leadscrew shear pin had done its job ! tried to punch this out all the way but really struggling to get the bit out that is embedded in the leadscrew shaft.
The Grizzly Manual says you can hammer it out while leadscrew is in place but wondering is it better to get the lead screw off and try hammer it out then so not to cause damage to the connecting cover and gear box bits and bobs.
ps Sorry …. another quick question when you fit the high speed belt on the pulleys (the one they leave in the box when you get the lathe delivered) are you supposed to take off the low speed belt or can you leave it on….reason being that there seems to be an awful lot of heat generated under the cover and the aluminium pulleys seem very hot so not sure if this is normal.
Thanks again
Matt
Edited By Matt Homer 1 on 13/06/2015 14:41:07
