I want to machine a small ring of steel to fit a small 30mm outside diameter, ball bearing into it. I want to make sure that the outer ring of the bearing doesn't revolve when in use.
How much smaller should I turn the inside diameter of the ring relative to the bearing outside diameter without decreasing the internal clearance of the bearing so much that the bearing locks up, but still doesn't revolve in the ring?
