Odd Stuff from the Web
Home Forums Help and Assistance! (Offered or Wanted) Odd Stuff from the Web
  • #177585
    Martin Kyte
      @martinkyte99762
      In Parallel with the thread Vanishing local shop outlets I thought it would be interesting to hear about some of the more obscure items or material sourced from the web. Workshop related of course. I recently bought 50mm of 1.5 mm diameter silver wire and a roll of transformer winding tape.
      What about you?
      regards Martin
      Martin Kyte
        @martinkyte99762
        #177588
        John Stevenson 1
          @johnstevenson1
          Got these this morning. Two job lots I'm well pleased with.
          Shed load of key steel and I do use a lot.
          Plus.
          Big pile of assorted slip stones, don't use these a lot but the rubber impregnated blocks at the back look interesting.
          Be able to hurl these at next doors cat and not get done for cruelty wink
          Edited By John Stevenson on 28/01/2015 12:22:22
          #177592
          V8Eng
            @v8eng
            Hurling key steel at a cat is a real waste of good material!devil
            #177593
            John Stevenson 1
              @johnstevenson1
              No the rubber blocks, that way if they bounce off they only get a corundum scrape
              #177598
              Ed Duffner
                @edduffner79357
                John, I have one of those rubber blocks (a memento from BAe in the 80's) They were used by the Spinner to polish up work pieces. I used mine to clean my N gauge track. I've also inherited one of those stones with a slight taper. Any idea what they are for? why the taper from edge to edge?
                Three or four years ago I set about designing a guitar tremelo unit that would not require routing the guitar body. To secure it I would have needed some Allen head wood screws. The only place I could find at the time was this place. They seem to be available from several suppliers nowadays.
                Ed.
                Edited By Ed Duffner on 28/01/2015 16:33:13
                Edited By Ed Duffner on 28/01/2015 16:36:17
                Edited By Ed Duffner on 28/01/2015 16:37:05
                #177602
                Gordon W
                  @gordonw
                  Taper edge stone- I've only used them for sharpening gouges. But will probably be for something else.
                  #177636
                  Ady1
                    @ady1
                    A Couple of things
                    RCH”>1
                    RCH”>2
                    #177670
                    Ian S C
                      @iansc
                      I'v got some of those tapered oil stones with the radiused edge, used them on gouges back in the days when I was wood turning. Used one the other day to freshen up the cutting edge of a 1/4" BSW tap. I usually use a little stone in the Dremmel.
                      Ian S C
                      #177750
                      Nick_G
                        @nick_g
                        Bought a bit of stuff recently on the web via 'that' site.
                        With me just starting out it's been an expensive year. There seems to be always something that you need when a newbie. – I dare not even think about adding it up.
                        But sometimes a bargain catches my eye. But a bargain is only a bargain if you actually need it. indecision
                        Anyway. Bought these items in the last 10 days ish.
                        The 80mm chuck is not exactly 'old' – It's a brand new one but 'old' surplus that someone was shifting for a price that I would not have forgiven myself for if I had said no to.
                        Nick
                        #177752
                          All very nice kit, Nick
                          Should last you a lifetime.
                          Anonymous
                            Posted by Nick_G on 29/01/2015 22:51:26:
                            Not so, there's the sheer pleasure of owning a beautifully made precision bit of kit.
                            #177776
                            Nick_G
                              @nick_g
                              Oooooops. My bad. blush
                              I originally read the thread title as 'Old stuff' not 'Odd stuff' that it actually is.
                              Nick
