Looking for opinions please. My electrical theory knowledge is not extensive.
I've recently taken on an Astra Elite AR5-E tool and cutter grinder.
Motor nameplate states ratings for 440V:
0.75HP
50Hz
1.15Amps
2800 rpm
There are six motor leads plus earth. The instruction manual gives directions for wiring the motor for 220V 3 phase. I've wired up a VFD and the motor runs nicely, but struggles to get going when changing the pulley to the two spindle high speed settings. According to the VFD display, no-load current draw at 50Hz is 0.4 amps ( this is with the 1:1 pulley belt attached, rpm check with an el-cheapo tachometer is 2550 rpm)
Q – When configured in 220V delta, will the motor require additional current compared to 440 star? I've heard it mentioned but wanted to confirm this is the case. If so, I'll cautiously increase the VFD current parameters from the nameplate rating. I don't want to fry an otherwise decent motor.
Also, would anyone know how many poles is motor likely to have?
Thanks all.
Edited By Stuart M on 14/11/2020 12:20:03
