Centec mill cutter speed
Home Forums Electronics in the Workshop Centec mill cutter speed
  • #489958
    Paul White 3
      @paulwhite3
      Hello all,
      A arecent thread contained reference to the odd vertical head gearing ratios on these machines, the
      poster had produced an electronic gizmo to drive the normal cheap Rev counter.
      I have fitted a VFD to the vertical head drive on my Centec and now have great difficulty in estimating cutter speed.
      Could the forum member concerned please contact me.
      Paul.
      Paul White 3
        @paulwhite3
        #489960
        Paul White 3
          @paulwhite3
          Previous post should be headed – Centec mill
          #490004
            It is 0.875 reduction, but I have yet to come across an application that requires a specific speed value of better than plus or minus 15% or more. Any theoretical cutter speeds are simply ‘ball park’ figures to be used as a starting point.
            #490010
            John Haine
              @johnhaine32865
              Assuming that .875 is between the motor and spindle and your VFD indicates Hz, and you have a 1440 rpm 4 pole motor, this table might help. If you run the VFD faster than 50 Hz (I use up to 100 Hz on my VMB) it's easy to extend this, ditto if your motor is actually 2 pole (2800 rpm).
              VFD Hz Spindle
              50 1260
              45 1134
              40 1008
              35 882
              30 756
              25 630
              20 504
              15 378
              10 252
              5 126
              Edited By John Haine on 10/08/2020 16:28:56
              #490011
              Paul White 3
                @paulwhite3
                NDIY, thanks for your response to my post. The heading was incorrect and the question badly phrased.
                I will try again- My centec mill has its own vertical head motor, this motor has a VFD . The net of this set
                up is that cutter speed has no reference . In a thread recently the poster passed an aside that he had
                made a gizmo to read the cutter speed, this I think was set by comparing the cutter speed as read on a
                hand held counter then setting the gizmo.
                #490019
                duncan webster 1
                  @duncanwebster1
                  I might be the person in question. My box of tricks takes the signal off the horizontal drive shaft, but if you have a separate motor and the top of the spindle is accessible it is a lot easier, a cunningly placed magnet will drive a Chinese tacho direct. Be warned that the update rate on the one I bought was really slow so not a lot of use for adjusting speed.
                  Of course you can make one of mine and not include the reduction factor as explained in the MEW # 294 article. My calibration tacho wasn't a handheld
                  #490027
                  john halfpenny
                    @johnhalfpenny52803
                    Or use a cycle computer. I have an £8 one. Set the wheel size as 1667mm, and the km/hr display is an analogue of rpm – ie for 24.4 km/hr read 244 rpm. The pick-up is small enough to put just about anywhere accessible on the spindle. A bit of maths on wheel size will accommodate a reduction gear.
                    Edited By john halfpenny on 10/08/2020 17:33:37
                    #490037
                      Is this a Centec head? Mkl, Mkll or Mklll? I suspect the Mkl may well be different to the Mklll, as might the Mkll, also.
                      I might sggest you adjust the pulley sizes, if belt driven, to provide an easy ratio. If direct driven, you only need to count the input turns for a number of output turns (or vice versa) and use a chart like John supplied above.
                      This is all dependent on the level your ‘fussiness’ for speed indications.
                      Motor power was different for original equipment, at least on the 2A and 2B models, so what power are you driving your head with?
                      Edited By not done it yet on 10/08/2020 18:26:07
                      #490108
                      Paul White 3
                        @paulwhite3
                        Thank you, to all the respondents to this thread.
                        The original objective was to identify the poster mentioning
                        centec head gearing, this has been achieved by Duncan
                        fessing up.
                        Ndiy- to answer your question, I fitted a1/2 HP ,3phase 1400 motor,
                        I don't know the head model no. , a picture of the set up exists in my
                        album.
                        I had hoped to read the shaft or motor speed, put that output through a very simple electronic item and feed that tto
                        the cheap tachometer units we all know. As this
                        now seems unlikely , a variant on Johns proposal, is the likely outcome.
                        #490133
                        duncan webster 1
                          @duncanwebster1
                          ……………I had hoped to read the shaft or motor speed, put that output through a very simple electronic item and feed that tto
                          Your conversion is very neat, saves having the horizontal gearbox thrsashing away al the time. Yet another project for the bucket list, you should write it up for MEW, even just a load of photos, there are lots of Centecs out there
                          Having had my article comprehensively rubbished in recent editions of MEW I hesitate to make any suggestions, but here goes.
                          John Halfpenny's solution is easy and will work
                          you could just put a scale on the vfd speed control knob, you'd need to borrow a tacho, or just work it out from the frequency display and pulley ratios as per John Haine
                          If you make the drive ratio from motor to Centec be 8:7 speed up, put the sensor magnet on the motor pulley. You're not looking for fabulous accuracy
                          Your final suggestion is possible, but would be nearly as much work as making one to my article, you'd still need a micro processor
                          #490147
                            The separate motor does give the option of altering the throat depth by an amount.
                            #490155
                            Paul White 3
                              @paulwhite3
                              Posted by not done it yet on 11/08/2020 14:37:10:
                              Duncan & Ndiy,
                              thank you both for your comments. It is very interesting to me that the points you make
                              cover my reasons for the drive mods – the std machine when fitted with single phase motor
                              was loud from the cabinet vibrations and gearbox noise. The separate motor has produced a silent operation.
                              The mod allows change in available work envelope both back and forth and up and down.
