There are no model engineering clubs in my area. I have already checked this because I was hoping to get somebody to teach me how to use a lathe. It looks like youtube for now when it comes to the lathe !
UPDATE : I assembled the engine and tried to run it off a small air pump but it would not work. I suspected that this air pump was not quite strong enough so I tried my air compressor which I use for the airbrush : SUCCESS ! The engine runs like a top and there is no ''clunk'' noise when it runs so it looks like that free play at TDC is not affecting anything at all. It really seemed like a problem when turning things by hand.
The nut holding the connecting rod to the crank does work it self loose after a few minutes so some Loctite 222 will be required ; it should arrive in the mail on Monday. I might also put a drop on the nut holding the piston rod to the piston as I would not want that to come off while it was running !
I managed to get the engine to run at less than 5 PSI ; sometimes it will even start without touching the flywheel. I have not yet sealed the grub screws in the port holes with thread sealant (Loctite 567) as per the instructions. I can feel air coming out of there so that should improve things a lot when I do that.
Thanks for all the advice.
Edited By Brian John on 27/04/2014 05:18:34
Edited By Brian John on 27/04/2014 05:47:47
