I've used a 3.5mm jack for one.
A bit more secure than the power leads & no change of accidentally connecting a power supply….
P.S. The flaming thing beeps if the probe isn't plugged in which is a PITA as I would like to use the box without it most of the time, I've just realised I could wire a fixed resistor across the jack socket that's switched out when I plug in the probe.
Edited By Neil Wyatt on 06/06/2019 10:58:48
