What are these electronic components called?
Home Forums Electronics in the Workshop What are these electronic components called?
  • #342869
    Ian Parkin
      @ianparkin39383
      I've never seen these used before what are they?
      the components in beige with a centrally positioned black line mainly unmarked on the board
      Ian Parkin
        @ianparkin39383
        #342871
        Frances IoM
          @francesiom58905
          2 are marked as being resistors on board – possibly being what appears to be a single sided board they are cross links or removable test links
          #342872
          Ian Parkin
            @ianparkin39383
            Yes i did say they were links
            what are they called and why in a resistor type package
            #342873
            Bodger Brian
              @bodgerbrian
              Posted by Ian Parkin on 23/02/2018 08:40:15:
              they are links but why in the resistor type package?
              Basically they're 0R resistors, used in this instance as links. The black band 'follows 'the standard resistor band coding, black signifying zero.
              The resistor type package is probably used so that it can be auto-inserted by machine. A simple wire link couldn't be handled that way and would need hand insertion.
              Brian
              #342874
              Dave Daniels
                @davedaniels93256
                #342878
                Ian Parkin
                  @ianparkin39383
                  well i'll be blowed i.ve never seen those before on any item of equipment i've repaired
                  thanks
                  #342879
                  Bodger Brian
                    @bodgerbrian
                    Posted by Ian Parkin on 23/02/2018 09:04:57:
                    thanks
                    Very commonly used…
                    Brian
                    #342882
                    Martin Kyte
                      @martinkyte99762
                      You also get them in Surface Mount.
                      regards Martin
                      #342897
                        I've never seen ones like that before, 0R SMT resistors yes, but not ceramic package.
                        Presumably it simplified manual assembly.
                        Much more interesting is what it comes from Are you a bass player, Ian?
                        John Rudd
                          @johnrudd16576
                          #342917
                          Ian Parkin
                            @ianparkin39383
                            Yes neil it comes from that
                            I try to play but better with banjo
                            Ian
                            #342918
                            Ian Parkin
                              @ianparkin39383
                              I have just ordered some for my stock £1.25 for 50 delivered !!
                              #342951
                                I have an ancient Laney Pro-Bass head with two 2×12 cabs and a tweeter box (because they were easier to carry up fire escapes than a 1×15 bigger than and heavy as a washing machine). Last year I got an orange Crush 20 practice amp, which is nice
