Not tried it myself but the negative reviews on Amazon are a concern, for example:
"This is a super affordable (and hence basic) DSO. Despite pocket change price it's not a toy but a rather functional device. Probably 10 years ago you would need to shell out at least a grand for a similar device. Heck, my fist oscilloscope was analog, weighted about 25 pounds and had one channel with 1 MHz bandwidth. Sure, it had an external sync input which I used may be two times in 10 years or so and mains sync which I think I never used…
Let's get back to this one… The software is indeed the weakest link here. But latest version 1.0.3 I got from the Hantek web site does the job. Triggering works fine and you can move graphs about both axes. Auto setting and measurements work OK. Sure, it's very basic and there are few advanced features. But hey, it's super affordable, remember?
Here are drawbacks which I find more annoying than inability to change graph colors or 2MB BMP files another reviewer mentioned:
1. Unsigned drivers. This is a BIG DEAL on 64 bit OS. It just won't work unless you disable driver signature verification (don't unless you know what you're doing). I just hooked it to my old laptop with 32 bit OS and it works but that is very annoying and there's no excuse for that.
2. As mentioned inputs are fairly noisy. Short the input and you can see about 8 mV noise with 20-25 mV impulses. Very noticeable at 20 mV/div, gone at 200 mv/div. I would guess it's a power supply filtering issue rather than the amp quality.
3. I found no way to AC couple the inputs. That is, inputs are always DC coupled, you'll need external capacitor for AC coupling.
4. No ADC overflow indicator. If you don't see expected signal check your range. If ADC overflows you get very wild signals.
5. USB is not insulated from the inputs. Completely expected at that price but watch out if you're pocking this scope into power supply or something…
To sum up: this is a basic and affordable DSO which does pretty much everything radio armature needs. Hook it up to your laptop and you all set. Overall construction is of high quality, probes are nice, has built-in 1 KHz/2V generator for probe calibration. Decent bandwidth, acceptable voltage range (300V at 1:10 probe), build it measurements and fairly small size works for me.
Update 05/25/2013: apparently driver is signed but missing some things needed to work on Windows 8 64 bit: .cat file.
I was able to create and sign that .cat file using instruction here:
http://stackoverflow.com/questions/10832499/workaround-to-skip-driver-signing-in-64bit-windows
First, edit the INF file and add these lines to the [Version] section:
DriverVer=05/25/2013
CatalogFile=Hantek6022BE.cat
Then proceed with CAT file creation and signing as described in the link. Do not sign .sys files, they are already properly signed."
That review is from 2013 and it's possible things have improved since then. Alternatively, this one (also from Amazon) gets less flak and is a bit cheaper.
For £50 with a money back guarantee you can hardly go wrong. Even a basic scope is better than no scope at all.
