Hi Hollowpoint,
It depends not just on how its wired, but also on how it's programmed – there are many ways of doing it.
I wrote up how I did it here:
http://www.model-engineer.co.uk/news/article/3-phase-conversion-and-other-alternative-methods-of-powering-a-mini-lathe/18752
I have speed, e-stop, start and stop all wired to a control box on the lathe. There's a switch on the speed control so when its at 'zero' it goes into jog mode. if find this really useful. I also have an analogue meter reading instantaneous power so I can see if I'm pushing 'the envelope'.
Wiring diagram below, the article includes programming advice that should give a pointer even if you have a different inverter.
