Grasshopper Engine
Grasshopper Engine
Home Forums Stationary engines Grasshopper Engine
  • #110486
    Kevin Norman
      @kevinnorman48306
      Does anyone know where I can obtain castings for the Grasshopper Engine by Sydney Owen, I know that Brunell do a similar engine but I do not really want to go down that path.
      Kevin
      Kevin Norman
        @kevinnorman48306
        #110489
        David Clark 13
          @davidclark13
          Hi Kevin
          Why don't you talk to Grahame?
          He may have it in stock.
          Give him a chance, see if you can do a deal.
          regards David
          #110492
            How similar do you want it to be?
            Bruce engineering do the Easton & Anderson that Anthony Mound described
            Stuart Models also do a grasshopper
            Or you could just make it from scratch possibly substituting a cylinder and flywheel casting from one of the other beam engines that Reeves do. I'm well on my way to completing a scratch built E&A at double the size of teh bruce offering with a lot more detail added, see here
            J
            Edited By JasonB on 30/01/2013 13:01:47
            #110495
            Kevin Norman
              @kevinnorman48306
              Thanks for your answers,
              I already have the drawings for the Syd Owen Grasshopper Engine and the two that have been mentioned from Bruce eng & Brunell do not fit the bill.
              My question was does anyone know of suppliers of castings for this particular engine , if not I have found a suitable flywheel and would machine the rest of the components from solid.
              Kevin
              #110496
                I've never seen castings available but they may have been in the sixtys when the article was writen
                J
                #110497
                Ian P
                  @ianp
                  Kevin
                  Sorry I cannot help you find an answer but I think David C has already mentioned the name of a potential supplier, he replied just few minutes after you first posed the question
                  I must admit that its not a supplier I know of, so you will have to Google it (or as DC again)
                  Ian
                  #110498
                  Kevin Norman
                    @kevinnorman48306
                    Thanks for your answer Ian , the supplier that David mentioned was Brunell and the Grasshopper Engine they do is not what I require.
                    Kevin
                    #110500
                    Ian P
                      @ianp
                      My reply was meant as a dig at DC!
                      I was not sure whether he was being ultra neutral as a moderator (in that he did not show any bias to any one supplier), but also, his reply meant absolutely nothing to anybody that did not know anybody called Grahame.
                      I know two people called Grahame but niether of them knows anything about casting, on the other hand one of them does go fishing,
                      Ian
                      #110502
                      David Clark 13
                        @davidclark13
                        Hi Ian
                        I misunderstood.
                        I thought you did not want to use Brunel for reasons posted on another thread.
                        I did not realise the engine was not what you want.
                        One of the Model Engineer contributors made it from the solid + a flywheel casting I think.
                        I think he wrote it up in ME but not dead sure.
                        That engine was an update of one published in ME back in the late40s, early 50s I believe.
                        It was also originally metric.
                        regards David
                        #110508
                          Would that be the one by A. Ebeltoft from March 1949? I have the drawings for that which are indeed in metric. Kevin, PM me if you want a copy.
                          Looks to be quite doable from solid and possibly a 5" Stuart Flywheel, bit on the small side for me but doubled up with a 10" wheel would be nice.
                          J
                          #110509
                          David Clark 13
                            @davidclark13
                            Hi Jason
                            I think that is the one.
                            regards david
                            #110515
                            Kevin Norman
                              @kevinnorman48306
                              The original design was by Ebeltoft but the drawings that I have are for the one serialised in ME Nov -Dec 1965 , I have the extracts from these issues.
                              The size of the engine is 13" long x 13" high x 61/2" wide and has 8 1/4" diam flywheel.
                              Kevin
                              #110569
                                Happened to be looking at Hit & miss engines and remembered that Canadian Model Engineering do a Grasshopper that is a dead ringer for the Owen one but looks to have been scaled up 50%. from the earlyer design, I had assumed they were the same size
                                Edited By JasonB on 31/01/2013 16:42:42
                                #110572
                                Jo
                                  @jo
                                  All the dimensions of that Canadian Grasshopper match the 1965 Sydney Owen design.
                                  Jo
                                  #110574
                                    Thanks Jo, another one to add to the collection?
                                    J
                                    #110575
                                    Kevin Norman
                                      @kevinnorman48306
                                      Thanks Jason,
                                      It matches the Syd Owen one to a tee , I will e-mail Canadian for more details.
                                      By the way what size of boiler would I need to power this size of engine?
                                      Kevin
                                      #110577
                                        Probably 4-5" dia the capacity is largish but hopefully it won't want too much steam as it should be quite slow running.
                                        I have heard that their Hit & miss castings are good quality so the same should apply to the steam engines.
                                        Make sure you post some pictures of progress.
                                        #110578
                                        Jo
                                          @jo
                                          Jason,
                                          I am still trying to be good and not buy any more castings. I already have my eye on something very sexy to add to my collection, something that I have no doubt will be both challenging and I anticipate will find very rewarding wink 2.
                                          Jo
                                          Edited By Jo on 31/01/2013 18:53:50
                                          #110579
                                          Kevin Norman
                                            @kevinnorman48306
                                            Thanks Jason, my GLR 4" vertical should be OK then.
                                            Kevin
                                          Home Forums Stationary engines Topics
