Through some extensive pleading I have managed to get a friend to print off a 3D printed nameplate to use as a pattern for some sand casting in brass or bronze. I've done some casting in the past but never using a 3D print as a pattern.
As it was difficult to get done (I felt really bad for asking, he is a busy chap) I don't really want to have to beg for another if this one gets damaged so I'm treating the original with kid gloves. That said the surface is quite rough. So will this cast ok? Would I be best off using a light coating of paint on top to help it to release from the sand? I'm using proper casting sand. The object is relatively small, 7cm x 1.5cm.
I don't mind the surface being rough on the finished article because I deliberately asked for it to be slightly oversize so it could be sanded back. I'm nervous about sanding the original for the reasons stated earlier. Excuse the fag packet sketch, it was done standing up!
![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Edited By Jon Lawes on 01/10/2018 12:23:19
