Like most thing when you have added the acetone to the abs is that you would need to make a mould very similar to casting metal so that you can overfill as when the acetone evaporates as this is part of the volume of the mix. Also something worth thinking about is the mould material will the acetone attack it so some research into that is needed
This part is more for information rather than what should be used for ABS plastics. I have cast polyester resins to make pens in the past an example in the picture below.
As for the use of a vacuum vessel this will remove the air and would need to be left under vacuum until everything it cured. if the material being put into a chamber is fast setting for example this could cause air bubbles to be suspended in the mix if fast setting materials are used a pressure put would be a better option as this will reduce bubble size
Edited By Derek Lane 2 on 13/08/2018 09:04:39
