Heated bed insulation
Home Forums 3D Printers and 3D Printing Heated bed insulation
  • #283161
    Greg Duckworth
      @gregduckworth98561
      Hi everyone,
      I am getting into 3D printing and I have read that my bed would benefit from some insulation underneath it. Has anyone on here got any experience or recommendations on what type of material to use, or any to avoid.
      Greg
      Greg Duckworth
        @gregduckworth98561
        #283168
        Barnaby Wilde
          @barnabywilde70941
          It's not a problem on my Qidi, but if I felt it needed a slightly faster heating time I'd probably opt for Cork.
          #283176
          wheeltapper
            @wheeltapper
            Ow blow it, I read the title and thought it would be about keeping warm at night.
            oh well.
            'sigh'
            #309158
            Nick Hulme
              @nickhulme30114
              I've just added insulation to the underside of my Mk3 Prusa bed.
              For support I used expanded Aluminium mesh with the edges bent up around the bed and trimmed off level with the top, this supports 4 layers of glass fibre tissue matting with a lower layer of Kapton tape to stabilise the glass fibres.
              I assume it's doing something as the insulated underside of the bed is now comfortable to touch with temp stable at 100C
              – Nick
              #309193
              Chris Baetens
                @chrisbaetens16442
                We succesfully used neoprene, cardboard, and also polystyrene on different printers.
                #309302
                Nick Hulme
                  @nickhulme30114
                  Posted by Chris Baetens on 28/07/2017 16:32:52:
                  I looked at lots of possible materials but eventually went for that which would be hardest to set light to in the event of an electrical fault 😀
                  #309306
                  clogs
                    @clogs
                    Wheeltapper,
                    l'm with u, get a younger woman like I did…….hahaha……Clogs
                    #309307
                    clogs
                      @clogs
                      Wheeltapper,
                      #309345
                        I've used a ceramic blanket, a bit of 12mm thick aluminium silicate blanket fitted nicely and made a very big difference to warm up times (and has probably greatly reduced the electricity use)
                        I also used a bit with some kapton tape to make an insulating blanket for my hot end (oo-err missus!)
