Help needed with rifle stock duplicator
Home Forums Work In Progress and completed items Help needed with rifle stock duplicator
  • #561144
    Neil Mccarthy 1
      @neilmccarthy1
      hi I have bought a incomplete air rifle stock duplicator it’s all done apart from the part that holds the wood and stock to be duplicated so they stay in the same place and turn identically as and when needed. The first pic should be what I have now the second pic show what I need or something similar has anyone any idea how I could do this please
      thank you neil
      https://ibb.co/4Fp6XZD
      https://ibb.co/jwHZWGL
      Edited By Neil Mccarthy 1 on 04/09/2021 00:00:30
      Neil Mccarthy 1
        @neilmccarthy1
        #561156
          If I understand the problem correctly … A pair of ‘timing pulleys’ and a toothed belt should do the job.
          Ref. https://www.linearmotiontips.com/how-to-specify-pulleys-for-synchronous-belt-drives/
          Edited By Michael Gilligan on 04/09/2021 06:37:14
          #561186
          Neil Mccarthy 1
            @neilmccarthy1
            Thank you very much I will look into that
