A while ago I asked if someone could recommend a water jet cutting company who would cut a couple of chassis’s.
I got them cut and have started building a 2.5cc class car, two pictures to show progress.
The chassis is cut from 12mm mild steel plate .
Here is the car so far more work yet to do, the engine needs the needle valve assembly making a support for the tuned pipe which was machined from the the solid and has a wall thickness of 0.3mm and a fuel tank there is just a wooden block at the moment.
When it gets warmer I will make the fibreglass top and bottom.
