Tap wrenches
Tap wrenches
  • #285539
    Benny Avelin
      @bennyavelin86238
      I have long tried to find nice tap-wrenches at flea markets, but have come short on the small sizes. I decided therefore to build one, well actually two, since one is for my father.
      So far I have made the adjustment nut.
      Adjustment nut
      Benny Avelin
        @bennyavelin86238
        #285541
        Anonymous
          Pretty darn neat knurling. thumbs up
          #285557
          mechman48
            @mechman48
            Neat knurling Benny; did you use scissor type tool or push on style ?
            ​George.
            #285568
            Benny Avelin
              @bennyavelin86238
              Thanks for the nice comments, I am quite happy with the knurling. Knurling has been fairly simple since I built my clamp style knurling tool. I also put some build images in an album.
              Tonight I will start on the body of the tap-wrench.
              Edited By Benny Avelin on 23/02/2017 12:59:13
              #285607
              Benny Avelin
                @bennyavelin86238
                Before dinner progress.
                #285635
                Benny Avelin
                  @bennyavelin86238
                  This is where I am finishing for today. Not so much turning left, next I will be milling the center part and the hole for the tap.
                  #285734
                  Ian S C
                    @iansc
                    A tap wrench is a ideal tool to make for someone starting out in any sort of lathe work, it's not too taxing on dimensions, but it will out last you in the workshop.
                    Ian S C
                    #285827
                    Benny Avelin
                      @bennyavelin86238
                      Hopefully they will last me a long time, regarding dimensions, I really need to get better with dimensions of length on the lathe, the diameter is fairly easy to hit.
                      #285828
                      Benny Avelin
                        @bennyavelin86238
                        This is the drawing I am using, but for some reason not following very well.
                        This is the setup I was using for support when drilling the center hole, worked well. I like my starrett adjustable parallel.
                        #285857
                        Vic
                          @vic
                          They're coming along nicely. wink
                          #285858
                          vintagengineer
                            @vintagengineer
                            I was taught hatched knurling was for knobs that needed pulling and straight knurling was for knobs that need twisting.But straight knurling seems to have gone out of fashion.
                            #285877
                            Ian S C
                              @iansc
                              Milling the flat part on a tap wrench(first milling job on my new mill)was where I learned that you DON"T use a Jacobs drill chuck for milling, the chuck fell out of the #3 MT taper, oh dear, the tap wrench has the nick out of it to remind me every time I use it.
                              Ian S C
                              #285881
                              Benny Avelin
                                @bennyavelin86238
                                Regarding diamond pattern or straight, I agree completely that straight is for knobs that need turning since they won't be that good for pulling wink On a serious note I would consider the pattern for a rotating knob to be cosmetical as you can choose either one or the other. However maybe you have some knob that you don't taunt to get pulled then straight would be a better choice. I chose diamond knurling for two reasons, one is that I don't have any straight wheels here as I have left them at my fathers place, second I don't want to drop this tool with oily hands. smiley
                                Anywho I always refer to this document when designing a part to check how much torque I can apply,
                                Here is some more great information about knurling and computing diameters and such.
                                Ian, I would have loved to do this project long ago, but I have gotten by on newly manufactured cheap tap wrenches and at some point I got fed up with the quality and decided to look for vintage tooling, when that failed I decided to make my own. I have also designed a bigger version with movable jaws that I will start making fairly soon.
                                #285882
                                fishy-steve
                                  @fishy-steve
                                  Hi Benny,
                                  They look very nice.
                                  I have a few tap wrenches to this design that I have acquired and they all have the same annoying problem. The pin that acts on the tap stems have all burred up. This isn't a problem when using smaller taps. The problem arises when you try to use it on taps that are at the maximum size for the tool. The burrs stop the pin retracting into the handle. At this point I usually throw the tool down in disgust and have to rummage around for a bigger tap wrench.
                                  As you will own the tool from new you might not have the same problem. The guy that owned mine before I acquired them must have been an ape. 😉
                                  You could make the 4mm pin out of silver steel and harden the tip. Just a thought.
                                  Steve.
                                  #285883
                                  Benny Avelin
                                    @bennyavelin86238
                                    Ian I remember a long time ago when I also tried to mill with a Jacobs chuck, but in a drill press disgust
                                    I was a kid back then and it was my fathers drill press, thank god he is a forgiving man.
                                    #285887
                                    roy entwistle
                                      @royentwistle24699
                                      I had to use a file when I made mine but then I was an apprentice @ 1950
                                      Roy
                                      #286019
                                      Nicholas Farr
                                        @nicholasfarr14254
                                        Hi Benny, nice work on your tap wrenches. On the question of whether the knurling should be straight or not, I can't say that I've seen any tap wrenches with straight knurling, all the ones that I have are diamond pattern, including this one below.
                                        This is No. 111 in the 1949 Moore & wright catalogue, it is about 5" long and can accommodate up to 3/8" taps.
                                        Regards Nick.
                                        #286028
                                          Posted by Benny Avelin on 25/02/2017 08:22:49:
                                          Useful links. Benny
                                          Thank You
                                          Benny Avelin
                                            @bennyavelin86238
                                            Posted by roy entwistle on 25/02/2017 09:05:29:
                                            Roy
                                            I would have loved to be an apprentice and learn how to file. Since I started this hobby on my own I did not start with filing since it seemed boring, however I constantly curse my crappy filing skills, which gets better and better but I should really force myself to file for a month or so.
                                            In fact I really love old school machining and do not really like carbide tooling, I see the benefit from I time perspective but the slow cutting speeds with sharp tools and cutting oil and the silent cutting action is like music to my ears and candy to my eyes. Once I get more space I will immediately get a shaper and a horizontal mill, beautiful machines…
                                            #286042
                                            Benny Avelin
                                              @bennyavelin86238
                                              Posted by Nicholas Farr on 26/02/2017 07:51:54:
                                              Regards Nick.
                                              Pictures like this is the inspiration for my tool (obviously), isn't it beautiful?
                                              #286044
                                              Benny Avelin
                                                @bennyavelin86238
                                                I decided to knurl also the other arm of the wrench, this is the tool in action.
                                                The finished result, I am really happy with the smooth action of the adjustment screw.
                                                Steve, I had thought about that issue actually and the plan was to make the 4mm push-pin out of silver steel and harden it, but I doubted that I could harden the tip and keep the pin straight enough. For this reason I decided not to harden it, but still made it out of silver steel since thats a bit harder than cold-rolled, but after reading your comment I went ahead and hardened and annealed the tip (thank you for this), without problematic distortion I might add. Again my filing skills could have been better and I struggled a bit filing the bottom vee grove to get it perpendicular and flat, but eventually it was passable
                                                #286059
                                                  Very nice Benny,
                                                  mechman48
                                                    @mechman48
                                                    Well done Benny; very nice clean knurling on both pieces.
                                                    George.
                                                    #286091
                                                    Anthony Knights
                                                      @anthonyknights16741
                                                      Here's one I made earlier (more than 50 years ago). No problems with burrs, as the parts which grip the tap are case hardened.
                                                      More recently I made a miniature tap wrench to use with small BA and metric taps.tap wrench bits.jpg
                                                      This shows it with a 12BA tap fitted.
