Straight off the crank like the majority of traction engines though a few were geared down. Not including those that only had injectors and no pump.
You say you have calculated that it needs 0.125″ stroke per rev, is that what you think will need replacing per rev due to the amount of steam used. If so you need to allow for when the engine is not running but the blower is on and using steam or if opening the drain cocks, etc. if it cannot replace more than it will use per rev once you run the engine to use the pump you will always be in deficite.
Jason
Edited By JasonB on 06/09/2011 20:36:25
