ME handbook Capstan and Turret Lathes
Home Forums Books ME handbook Capstan and Turret Lathes
  • #595571
    Mike Waldron
      @mikewaldron61652
      I have been reading Edgar Westbury’s articles of 1942 on building the ‘ME Capstan Attachment for Small Lathes”, and came across this phrase on page 500 of the 21st May 1942 edition:
      ”Information on the design and operation of automatic indexing and locking gear was obtained from THE MODEL ENGINEER handbook, “Capstan and Turret Lathes”….”
      Does anyone have such a publication? Or access to a copy?
      Mike Waldron
        @mikewaldron61652
        Search for information
        #595573
        DC31k
          @dc31k
          You could ask a Mike Waldron, who claims in this thread to have the pdfs…
          https://www.model-engineer.co.uk/forums/postings.asp?th=149012
          It is available on Abebooks:
          https://www.abebooks.com//servlet/SearchResults?tn=Capstan+Turret+Lathes
          #595574
          David George 1
            @davidgeorge1
            Having been an operator of capstan lathes around 1970 ish making things like 500,000 screws for a missile launcher axles for caravans, and parts for RR aerospace ie 1/4 UNC studs by the thousand. Is there anything you need to know about capstan lathes.
            David
            #595579
            Mike Waldron
              @mikewaldron61652
              David: you’re a star!
              Thanks again for the availability of your know-how!
              It’s just that I’d like to read that particular text, really. I already have a book on the subject, but not actually the one mentioned… so I wondered if it was still obtainable, or accessible.
              I’m fairly acquainted with Ian Bradley’s work, under the Duplex name, but I’ve not come across much of Edgar Westbury’s writings except the Capstan Attachment articles.
              Rest assured I’ll be on the email again for tips and wrinkles, thanks again David!
              #595583
              Trevor Drabble 1
                @trevordrabble1
                Mike , I have a copy available with damaged cover , but am afraid it will be some time before l can look for it . Trevor.
                #595595
                steamdave
                  @steamdave
                  I also have a copy but postage from Ireland will be quite expensive. If you can wait until July time, I will be in Blighty then if you haven't been satisfied beforehand.
                  The Emerald Isle
                  #595676
                  Mike Waldron
                    @mikewaldron61652
                    Gents
                    Thanks for your responses, and apologies for ‘senior moment’ repetition of the subject.
                    I hadn’t been able to access some of the previous suggestions, so had given up on the thread, but have now found the copy as advertised on Abebooks, so will progress down that route.
                    Further: I did try and discover whether ‘Ned’s’ article ever extended to the automatic chuck that was mentioned in the text as possible (back in the day) but I don’t think we ever found an answer to that query.
                    #595705
                    Bill Davies 2
                      @billdavies2
                      Not identical text, but is this related to the article that Mike has mentioned? Dated 1941.
                      I know it doesn't answer Mike's question, but others may be interested in this article.
                      Bill
                      #595759
                      Bill Davies 2
                        @billdavies2
                        A simplified diagram of the capstan indexing and stops mechanism is shown on page 19:
                        Capstan and turret mechanism
                        Bill
                        #595782
                        Mike Waldron
                          @mikewaldron61652
                          Went for the book on capstan lathes only to find someone else had bought it first!!
                          ok which of you was it?
                          Edited By Mike Waldron on 25/04/2022 17:20:47
                          #595783
                          Bill Davies 2
                            @billdavies2
                            Posted by Bill Davies 2 on 24/04/2022 22:18:48:
                            Bill
                            Try again…
                            Small lathe capstan
                            #595791
                            David-Clark 1
                              @david-clark1
                              Any book on ward and Herbert capstan lathes might be useful as well.
                              #595802
                              Peter Ellis 5
                                @peterellis5
                                I have an an attachment as per the original article and I probably have the book as well.
                                #595821
                                Peter Ellis 5
                                  @peterellis5
                                  Confirmed. Yes I do. It is about setting them up rather than making one as per the ME article, though.
                                  Cheers
                                  Peter
                                Home Forums Books Topics
