Ega, I think you probably followed the directions that Michael refers to.
Don't have my scratch pad in front of me but the math goes like this:
For 66 holes, the angle between two holes = 3600/66 = 54.54
54.54 is the angle in tenths of a degree, due to the 3600 in the formula, rather than 360.
So, we use the sector arms to mark out the 54 tenths of a degree. In a 60 hole circle used for indexing in this case, each hole = one tenth of a degree. (One revolution of the handle = 360/60 = 6 degrees. 6 degrees divided by 60 holes = .1 degree.)
Then we use the micro adjustment dial to move the 00.54 tenths of a dergee each time.
So the movement becomes 0 turns of the handle, plus 54 holes in the 60 circle, plus 54 graduations on the micro adjuster. Result, as tested = 66 hole circle perfectly formed.
Alternatively, if you follow the 9/54 misprint, each movement equals an angle of 9 x 6 degrees = 54 degrees, plus the 54/1000ths put on by the micro adjuster. Or 54.054 degrees. If you drill 7 holes to this specification, the seventh hole will fall at the 378.378 degree mark. which is 13.378 degrees past the first hole you drilled. Nowhere near the needed 5.45 degrees between two holes in a 66 circle. It's just totally wrong. Whereas the 0/54 formula is spot on.
I think I got my math right – but I majored in English Lit so don't take it for granted.
