I had 3 & Any bits of metal may penetrate the polythene bags & let the air out. Wood chips that are sharp sometimes used to do this on thin bags.I forget the gauge, but you may need a heavier one than the standard that one you may get.
You may want 50mm hoses to your tooling if expecting to move it about during use as the standard 4 inch is too awkward & by the time you reduce the hose size you get little more suction than a Henry cleaner.
Not worth it, unless permanently attached to a static wood machine such as a planer, thicknesser, saw etc
