Posted by Godfrey King on 24/01/2014 21:56:15:
I have been told that there is a problem with the cheaper ie £100 inverters with lack of torque and limited speed range and that you will still have to do some belt changing, is this right?
VFDs are not torque multipliers. They don't work like gears, where halving the speed doubles the torque. In essence, a VFD driven motor will give constant torque at speeds at and below its rated speed (ie. its speed at 50hz in UK), and constant power at speeds above. This means that power is proportional to speed up to the rated speed, and then remains constant up to maximum speed.
There are VFDs that purport to give increased torque at slow speeds, but I don't think its significant (can anybody supply more information?)
I've fitted cheap VFDs (around £50-£70) to 3 mills, 3 lathes and a bench drill, all of them will work up to 120hz – that means that a 1425rpm motor will spin at 3420rpm.
I seldom change the gears or belts on my machines; I use the VFDs instead, but there are occasions when I need the extra torque that only gearing can provide.
Gary
