In the spirit of generous tips given on this board I would like to make a modest contribution
In my travels I came across this little gizmo. Its a tct saw blade which you can fit on a 4in angle grinder. IMHO its an incredibly useful tool, so easy to hold for simple wood sawing jobs, much easier than a dangerous heavy circular saw but of course it only cuts to a depth of 2in. I use mine often.
I only got a selection of blades out in the far east for 5quid each but see they are available on ebay now for about 7quid
Once youve had one you wonder how you managed before, My neighbour's always borrowing mine – Ill give him one for xmas
ebay.co.uk/sch/i.html?_nkw=tct+saw+blade+115mm&_sacat=0&_odkw=tct+saw+blade&_osacat=0&_from=R40
Important thing to note is the od is 115mm, the bore is usuall 20mm but you angle grinder normally uses 22,5mm so a little work on your ML7 to cut a little should on the clamp ring is need.
The blades need sharpening after a while especially if cutting chipboard so I got a small diamond sharpening blade which I will try out
See my gallery for pix
Cheers
Robin
