Silver solder guiding
Home Forums Hints And Tips for model engineers Silver solder guiding
  • #96526
    David Haynes
      @davidhaynes53962
      Hi,
      I have two gaps close to one another, one must be soldered and on must not, they are all part of the same part. If flux is used on the joint to be soldered, is there something to prevent solder taking, aside from oxide and lack of flux?
      Edited By David Haynes on 17/08/2012 10:05:49
      David Haynes
        @davidhaynes53962
        Keeping silver solder away from specified areas
        #96529
          Tippex.
          But I've not tried it myself. I think the idea is to contaminate the area so the solder won't take to it and a chalk based covering will resist the heat.
          #96530
            Tipex correction fluid works well, here it is being used to stop the parts sticking to the jig
            J
