Hi, I made a left and right hand M8 brass threaded rod with split hand dies. I held the rod in my collet chuck on my mini lathe and started the die while putting a little pressure on the die itself to keep it square to the rod, with a blank end arbor in the tail stock and turning the chuck by hand, then once the full width of the die was on, the rod was supported with a revolving centre, the left hand thread is a little longer than the right hand one and is about 110mm long.
This is for my Swiss Boy 116 lab jack. Swiss Boy 116
Regards Nick.
Edited By Nicholas Farr on 15/04/2022 08:54:31
