Etch Primer life
Etch Primer life
Home Forums Materials Etch Primer life
  • #30186
    Bob Unitt 1
      @bobunitt1
      Bob Unitt 1
        @bobunitt1
        Does anyone know how long Phoenix 2-part Etch Primer remains usable for brush application once mixed, if kept in a sealed container ? I tried emailing them with this question, but no response sad
        #574669
        Robert Atkinson 2
          @robertatkinson2
          Any 2 part paint is unlikely to keep for very long once mixed. Putting in the fridge will help. Some 2 part materials can be frozen once mixed to stop them curing. This is used for some ircraft sealants.
          The Phoenix website says 3 hour pot life. Closing the lid will make no difference to this.
          https://www.phoenix-paints.co.uk/products/60pq31
          Robert G8RPI.
          #574673
          Adrian R2
            @adrianr2
            On Youtube you can find a video from "Trev's blog" where he shows how to carefully weigh out and mix small quantities of 2 pack paint – OK that is automotive small, not model engineering small, but may still be helpful.
            #574674
            Martin Kyte
              @martinkyte99762
              One year if I remember correctly.
              regards Martin
              #574679
              Bob Unitt 1
                @bobunitt1
                Posted by Robert Atkinson 2 on 08/12/2021 12:31:49:
                Robert G8RPI.
                I thought that time-limit was just for spraying ? I know the 1-part primer is good for a month before it loses the ability to etch, and was wondering if the 2-part is just the components of the 1-part in a form which will last longer until mixed ?
                Edited By Bob Unitt 1 on 08/12/2021 14:36:38
                #574681
                Oldiron
                  @oldiron
                  Posted by Martin Kyte on 08/12/2021 13:24:30:
                  regards Martin
                  Only when unmixed.
                  regards
                  #574695
                  Dave Halford
                    @davehalford22513
                    Posted by Bob Unitt 1 on 08/12/2021 14:33:05:
                    Robert G8RPI.
                    Bob,
                    Think of it as a car body filler, once you add the oxidizer hardener the result is only altered by temperature.
                    1-part is ordinary acrylic paint and dries mostly by solvent evaporation.
                    2-part requires the hardener to be added to effect 'drying' and based on isocyanates it's very nasty to breathe.
                    The etch action is an entirely separate to the drying process
                    #574710
                    Steviegtr
                      @steviegtr
                      I think here the general rule is, only mix what you need. There is no need to mix the whole tin. I use 2 part products a lot. Fibre glass resin. Primers, & clear coat. I try & work out how much i need & then just mix a little more.
                      Steve.
                    Home Forums Materials Topics
