What Material for this Application Please?
Home Forums Materials What Material for this Application Please?
  • #565002
    Martin King 2
      @martinking2
      Hi All,
      I have been asked by a neighbour and friend to make a wind break for their garden.
      The main frame will be welded 25mm steel box section with fixing tabs to take the main panel as shown.
      The pal's wife would like it to be "copper" but I am guessing that any copper sheet of suitable thickness would be way too expensive.
      I would welcome any suggestions as to a suitable alternative that would be weather proof and not too heavy.
      Powder coated something? PVC sheet?
      Cheers, Martin
      Martin King 2
        @martinking2
        #565003
        Martin King 2
          @martinking2
          Size is 1.8m tall by 1.25m width
          Martin
          #565006
          Nick Wheeler
            @nickwheeler
            Does it have to remain flat, or can you roll some ribs into it?
            A flange on the unsupported edge would be a good idea.
            Using both of those would reduce the need for a thick sheet.
            Would a galvinised finish be suitable?
            #565007
            pgk pgk
              @pgkpgk17461
              Solid bronze coloured polycarbonate?
              Anodised ally colour (assuming someone does those sorts of sizes)?
              Hammerite copper paint does look like copper?
              Gild with copper leaf?
              Thin copper sheet sandwich over something?
              pgk
              #565008
                Can’t recall the name just now, but : There is a grade of steel sheet, beloved by Architects, which rusts gracefully to a sort of self-protecting surface.
                Edit: __ see here: https://www.metalsheets.co.uk/corten-steel-sheet/
                Edited By Michael Gilligan on 01/10/2021 08:46:21
                #565009
                Stueeee
                  @stueeee
                  If that windbreak is not in a very sheltered position I think I would use 40mm box section for the frame rather than 25mm. There's quite a square footage of screen/sail there which could buckle the frame in a storm.
                  re. the finish, If you used aluminium sheet, you could get it treated with a translucent copper powder coat like this: weblink which should give an approximation of clean copper without the eye watering cost.
                  #565012
                  Robert Atkinson 2
                    @robertatkinson2
                    Some of the imfamous plastic cored decorative building cladding comes to mind. Aluminium composite material (ACM) panels
                    Metal faced for durability but the platic core makes it stiff and "dead" so won't act like a wobble board and make a lot of noise in the wind.
                    If they are de-cladding a building near you it might even be free.
                    Robert G8RPI.
                    #565014
                    John Haine
                      @johnhaine32865
                      A house in the village has a fence made of pierced steel sheet which I think must be the type that Michael suggests, It has "rusted" to a nice reddish colour. We also have a garden ornament made of something similar which looks nice.
                      #565018
                      John Haine
                        @johnhaine32865
                        Just to addd that you could probably get steel laser or water-cut to shape, and in the process they could perhaps cut out a pattern in the panel for decorative effect and reducing windage.
                        #565019
                        Journeyman
                          @journeyman
                          Composite fence panel possibly see ** My Modern Garden **
                          Weathered steel ** Corten Garden Products ** from BuyMetalOnline.co.uk
                          Cheapest route would probably be to use a sheet of OSB and paint it! Should last 10 years or so.
                          Edit: add link
                          Edited By Journeyman on 01/10/2021 10:15:48
                          #565021
                          ega
                            @ega
                            Posted by Michael Gilligan on 01/10/2021 08:42:12:
                            Edit: __ see here: **LINK**
                            I think this is like the "weathered steel" of the Kew Gardens treetop walkway:
                            https://www.kew.org/kew-gardens/whats-in-the-gardens/treetop-walkway
                            #565028
                            blowlamp
                              @blowlamp
                              Tricoya waterproof MDF would probably do the job. You could finish it in almost any way you like.
                              Martin.
                              #565045
                              Jon Lawes
                                @jonlawes51698
                                Another vote for the aluminium composite sheets; that design is a massive sail!
                                It's very strong and could be painted or left as the manufacturers coloured surface.
                                #565063
                                Adam Mara
                                  @adammara
                                  And another vote for ACM sheet, but would opt for 5mm rather than 2 or 3mm. Depending on budget, you can stick printed vinyl sheet to it, or even have it printed on directly. Unfortunately sheet they use at work is in short supply at the moment, and the prices keeps rising.
                                Home Forums Materials Topics
